tc-88 timing question
Old Sep 1, 2014 | 02:57 PM
BiggestDawg's Avatar
BiggestDawg
Advanced HDF Member
Default tc-88 timing question
I have an 2000 FLHTCUI that I just installed the SE Cam Support plate in with new stock cams and bearings. I have aligned all the marks on the cams per the instructions then on the Primary Cam Sprocket and the Crank Sprocket. I put it all together and fire it up and it is not running correctly at all. I can see fire though the intake and it is popping and I am getting air pushing out of the intake. I pull it apart and verify that all marks line up and they do. So what else am I missing here?
Old Sep 2, 2014 | 12:25 PM
BiggestDawg
Advanced HDF Member
No one answered here but I did figure it out. It was the push rods for the front jug! I was getting tired the night before and though I tried to make sure I had the correct I managed to switch the intake and exhaust rods and there you have it. Switched to the way it should be and put it all back together and it purrs like a kitten now
keatingiv
May 27, 2026 09:23 PM
skinman13
Engine Mechanical Topics
25
Mar 20, 2017 02:45 PM
BiggestDawg
Sep 1, 2014 07:18 PM
Spur56
Feb 9, 2012 02:10 PM
nemick
Mar 3, 2009 03:40 PM
