Cam Timing Question
Old Mar 3, 2009 | 01:07 AM
nemick's Avatar
nemick
Default Cam Timing Question
I saw on an advertisement from my local dealer, that the SE 255 cam has 4 degrees of advance timing built in to it. Is this the case with cams from other manufactures or would I need to do some type of adaptation?
Thanks
Old Mar 3, 2009 | 01:52 PM
nemick's Avatar
nemick
Anyone got a clue about this?
Old Mar 3, 2009 | 02:06 PM
HDRider2002's Avatar
HDRider2002
I've read a few posts on here about 4degree timing advance sprockets to essentially do the same thing to other cams without the advance, i'm sure someone will chime in eventually and give you the low down.
Old Mar 3, 2009 | 03:40 PM
Harleypingman's Avatar
Harleypingman
This is a pictorial representation of cam timing events for a specific SE cam taken from the SE Racing Parts catalog:
http://
Most of the bolt-in cams (Woods 6, S&S 510, Andrews 26, etc.) have an intake close of 40* and on stock compression engines are often installed with a 4* advance key to close the intake earlier. HQ-0034's have an intake close of 36*. The earlier intake close raises the CCP, and moves the torque band earlier in the rpm scale.
I don't recall the intake close of the SE 255 cams, but you can find it and many others using the BigBoyz cam comparator on their website. Your dealer is really saying that the 255's have an earlier intake close than many of the other popular bolt-in cams and doesn't need an advance key.
Jackpoticorn
Jan 1, 2015 08:54 PM
Duc
Jul 29, 2014 03:00 PM
LouEyez
Mar 3, 2011 09:16 AM
hougz79
Sep 6, 2010 10:20 PM
hadlje
May 20, 2009 12:37 PM
