Ironhead A place to talk about Ironheads.
76 xlh carby problems i think
Old May 9, 2007 | 09:14 AM
76hdiron's Avatar
76hdiron
6th Gear
Default 76 xlh carby problems i think
hi there, iam a new member . wanting some advice .
i have a 76 xlh i have had it for 6 yrs.
top end was rebuilt. carby was changed , but the mixture screw was butcherd so i put the old crab back on (as it WAS running fine with it on ) its a zenith carb.
ok the problem is i set mixture screw so bike iddeled fine open the throttel and it surges. then when it is hot it is very temermentel to start .
some times i let it sit for 1/2 hour then it will fire..iam thinking pump probs...
so any advice would be help full..and it is elec.start only
craig
Old May 9, 2007 | 10:39 AM
piniongear's Avatar
piniongear
Default RE: 76 xlh carby problems i think
What do you mean by 'engine surges' when you open the throttle? It cuts out?
If the carb ran fine before, you can expect it to run the same later. Sitting on a bench does not degrade the carb.
So you may want to take another look at how well the intake manifold is sealing at the 2 O-rings. If the engine is popping, this is the problem. Remove the carb and then remove and reinstall the manifold, making sure both O-rings do not shift when you tighten the clamps.
While you have the carb off.......drop the float bowl and check the float level. Be sure to check the O-ring that is located on the main jet body. This thing has caused me grief no end in the past on my Zenith (Bendix) carb. Photo of this is attached.
If you need a new O-ring, go to Lowe's and buy a pack of 10 in the plumbing dept. You want a #5 size. This O-ring will degrade over time and allow fuel to bypass the main jet by leaking directly into the inlet manifold. This item is the only thing (inside the carb) I can think of that will degrade while the carb sits there on the bench over time............pg
[IMG]local://upfiles/8331/FC58564FA8DD4200B5BCB22B6A31B4D2.jpg[/IMG]
Old May 11, 2007 | 09:48 PM
76hdiron's Avatar
76hdiron
6th Gear
pg
thanks for advice..you are right ,i thought carb would be fine also ..but surge as in open under load quickly it plays up open throttel slow it is ok
so i will check o ring and let u know how i go ...also will check float level;; its not popping so i dont think it is sucking air in
cheeres craig
Old May 11, 2007 | 10:02 PM
piniongear's Avatar
piniongear
OK, it will be worth a look inside the carb. If the O ring is degraded another affect is that the exhaust pipes will be sooty black at the ends. When it gets really bad the spark plugs will foul at high speed with the sooty deposits from the raw fuel........pg
Old May 12, 2007 | 01:22 AM
76hdiron's Avatar
76hdiron
6th Gear
pg .
thanks for your help.
i found the problem , it was the mixtuer screw must of been dodigie
i replaced it and it is performing 100 percent like they should.
i replaced the o ring also ( for peace of mind)
thanks mate
Old May 12, 2007 | 10:14 AM
piniongear's Avatar
piniongear
76hdiron.....
Great! Glad to hear you have it humming. Yes, a bad needle sounds like the answer. Good that you replaced the O ring while you were there.
Should the bike ever start to run rich.....black puffy smoke out the pipes and spark plugs fouling at highway speed....then look for that O ring to be the cause.......pg
Big Pap
Exhaust System Topics
Dec 1, 2012 10:49 PM
alitterit
Jul 21, 2012 03:49 PM
Jaystn62
Mar 14, 2012 02:19 AM
bryon857
Ironhead
Feb 21, 2008 06:56 PM
Rolson1
Ironhead
11
Sep 21, 2007 12:58 AM
