Please help wiring 81 ironhead
You need the complete ignition kit but you do not need the programming kit
http://www.ultimaproducts.com/programmableignition.html
Install instructions
http://www.ultimaproducts.com/53-644_Ignition.pdf
A reliable eBay seller, best price
http://www.ebay.com/itm/ULTIMA-SINGL...RWy2gD&vxp=mtr
If you get this I'll pass on more detail about the install instructions.
If the vin matches the engine and not the frame , thats bad. Your paper has to match the frame, no other place counts
You need to buy the two factory manuals. You will get no where fast unless you have both. We can only be so helpful when you do not have even the basic information to use the correct terminology. Here is what you need ...
99484-85 Factory Service Manual
99451-85A Factory Parts Catalog
These are widely available. Put the part numbers into the Google and eBay searches, or buy from a local Harley Davidson shop or from a local indie motorcycle shop.
If you are looking for parts anywhere whether it be eBay or a local Harley Davidson shop or from a local indie motorcycle shop you must have the exact correct part number. The only way to get these is to have the factory manuals.
These manuals contain the correct wire diagrams for what you have. It is important to be able to determine what is there that is correct and what has been mangled by the procession of previous owners throughout the history of that motorcycle
The FSM is the only source of information available for the electronic ignition system on your motorcycle.
My advice on the Ultima ignition still stands. You will find very few members of any of the IronHead and vintage motorcycle forums are familiar the electrical and electronic systems of that year, which ever one it happens to be.
Post pics of what you call the CDI box and the module behind the ignition cover that might be a Dyna S. The S and the OEM module look similar but we might be able to tell from pics.
Here's the Dyna S instruction sheet ...
https://zodiac.nl/docs/instructions/232290.pdf
Here's a Dyna S ignition system ...
http://www.jpcycles.com/product/380-623
Do a Google search for 1981 sportster ignition module and you will get pictures of the original parts.
