Ironhead A place to talk about Ironheads.
71 XLCH Dies while riding
Old May 8, 2024 | 04:02 PM
carlgrover's Avatar
carlgrover
You might check the taillight wires as they run along/inside the fender and not just in the taillight itself. I've never done it on my ironhead but I was shocked when I saw how the taillight wires ran through the inside of the rear fender.
carl
Old May 8, 2024 | 06:39 PM
Spooch22's Avatar
Spooch22
carl
Screwed around a little today with it. I pretty much tried all I could to trip the CB again. I pushed,pulled,rubbed and twisted the wires leading to the taillight and all good. Could it be the bulb wasn’t seated properly? I pretty much just removed and re installed the bulb and problem went away.
Old May 9, 2024 | 06:31 PM
Spooch22's Avatar
Spooch22
Checked things out again today. Started by checking for short in taillight.Not much going on in there it looked all good. I removed bulb to check everything out. Re installed the bulb and popped the CB. I noticed the brake light wouldn’t come on when brakes were applied and when lights were turned on the taillight was bright like when brakes are applied but they weren’t. I removed the bulb and noticed it wasn’t installed correctly as it has staggered slots when you insert it. After installing the bulb correctly took the bike out for a short ride and everything worked perfectly. Go figure. 🤪
Old May 15, 2024 | 05:36 PM
carlgrover's Avatar
carlgrover
Glad it worked out.
carl
Old May 16, 2024 | 06:49 PM
Spooch22's Avatar
Spooch22
Thanks for the help. I’m still not sure a improperly installed bulb could cause a tripped circuit breaker but I’m going to go with it for now. 🤔
Old May 17, 2024 | 06:49 AM
johnjzjz's Avatar
johnjzjz
No that was not it - its in the power to wiring but the headlight has a nest of wires in it AS well as going to and from the headlight
many times have found a chaffed wire in or around the headlight - now that you have re positioned the wire harness pulling on it your moved the issue
pull the gas tank make sure a wire edge is not being squeeezed - around the coil the white wire is suspect from the ign switch - ignition switch is the once in a blue moon falter thing but it happens - directional wires orange is power if not used maybe one is grounding - you cant let it fool you into thinking everything is ok
just pull up a chair and have at it till you find it - if not 50 miles from home no cell service on a dark hi way at night RT 80 in jersey is the speed limit it seems and they have made the shoulder the passing lane and a monsoon starts will teach you to make sure you found it next time -
Old May 17, 2024 | 02:10 PM
Spooch22's Avatar
Spooch22
Yeah I’m not that lucky. Always pisses me off when these issues happen on such a sweet running bike. Not my first rodeo as I’ve been riding vintage bikes for many years. I’ll dig in again but I just want to ride the damn thing.
Old May 23, 2024 | 08:22 PM
Spooch22's Avatar
Spooch22
You nailed it John!! Found a orange wire behind headlight was chafed. Looks like it was grounding itself on a bracket just below the bar clamps. Got to be honest still a little nervous with these things but zero issues since I found and repaired the wire.
Old May 24, 2024 | 03:10 PM
johnjzjz's Avatar
johnjzjz
See
capekdw20
May 2, 2023 01:39 PM
Wave Boreal Forest
Jul 17, 2021 02:43 PM
ThatRyanGuy
Electrical/Lighting/Alarm
Oct 16, 2017 09:15 AM
kyknights
Ironhead
Apr 9, 2008 12:45 PM
