Ironhead A place to talk about Ironheads.
No compression
Old Sep 23, 2024 | 12:32 PM
Abilyeu's Avatar
Abilyeu
Originally Posted by Racepres
^^ Why, in the Wide World of Sports, is the Folks at the Keyboard Always tearin **** Apart??? If nothing else, I get old stuff runnin Before I tear it Down, Just to run Water thru to "Clean" it Out.. Besides...If nothing more than a Numb Nuts adjusted Pushrods Wrong... Some Serious Waste of Time and Effort!!!!
It starts up easily and idles decent first through third has the power but right when I get into fourth just loses all of it, if I can avoid busting into the engine I definitely will but I’ve never had to deal with compression issues
Old Sep 23, 2024 | 12:40 PM
Abilyeu's Avatar
Abilyeu
Originally Posted by pgreer
If the OP has more info or history on the bike and engine in particular, they should provide it. And sure it's an old Sporty that we know eats valves and guides, but the picture of the plugs from another post didn't look bad in terns of burning oil, although I don't know if they were installed the week before the picture was taken. But if it were mine, I would spend time diagnosing the actual problem befire tearing it down. Including checking pushrod adjustment because that could affect compression. Although that may be what is eventually required.
Paul
the plugs were on the bike when I got it I haven’t changed it I was gonna change when I got the carb figured out but since I did the compression test just been trying to figure out what’s wrong, I think the carb issue is taken care of got a new carb( it had a cheap copy of a mikuni on it) and re jetted lower for the altitude. The guy I got it from doesn’t know anything about it dude didn’t have it long I’m thinking
Old Sep 23, 2024 | 12:42 PM
Abilyeu's Avatar
Abilyeu
Ensure a Big Twin Mechanic did Not adjust the pushrods!!First..
Don't laugh...Seen it back when we had a Shop!!! Guy was adamant that he adjusted Pushrods on his Stock Shovelhead ...by the Book.
Sadly it was a Sheet Metal Copy, Ironhead!!
yeah that would be wild! I don’t think this one has that issue but good looking out!
Old Sep 23, 2024 | 12:44 PM
Abilyeu's Avatar
Abilyeu
Originally Posted by TexasScooterTrash
Some Folks at the Keyboards like to think that the person who is posting a problem does his due diligence to try to resolve it. For me, I look up what was posted previously by them to better understand his issue. We're talking about a 1971 Ironhead here. A top end job on a 53 year old engine is not a bad suggestion. Sorry if you don't like my thoughts on his bike.
top end job is definitely needed I’m sure if I can get away with waiting until winter to do that, that would be great haha if not no worries. It’s gonna get done either way just wanna squeeze some fall riding in hopefully
Old Sep 23, 2024 | 01:52 PM
Racepres's Avatar
Racepres
What was the compression reading then???
Old Sep 23, 2024 | 02:32 PM
Abilyeu's Avatar
Abilyeu
front almost 90 and rear a bit above 30, the rear I feel no resistance
Old Sep 23, 2024 | 09:05 PM
Racepres's Avatar
Racepres
I'm going to Concur with Texas Scooter Trash Now...Heads gotta come off...But...Before ya do..did you do Compression test with and Without oiling cylinders?? Result?
also I assume you held Throttle Wide Open!!
One thing I would definitely do..before disassembly,, Loosen pushrods on that rear cylinder... test again..
But...even 90 is Lame for an Ironhead!!
Edit; If everything is done correctly...My Bet is a very Bad Valve...and of Course a Well Worn Engine complete..
Old Sep 23, 2024 | 09:10 PM
Abilyeu's Avatar
Abilyeu
I didn’t test with oiling them just let the bike warm up for a bit then turned off gas, throttle fully open key on and kicked until it stopped going. Top ends gotta be gone through never done that before so hopefully I don’t mess it up
Old Sep 23, 2024 | 09:19 PM
Racepres's Avatar
Racepres
You won't be the First to try to Obtain Mechanical Aptitude, on an old Ragged out Ironhead..
If you succeed...do you want a Couple More???? Seriously!
Old Sep 23, 2024 | 09:22 PM
Abilyeu's Avatar
Abilyeu
Definitely! This is the third old sporty I’ve had they’ve all had issues but never compression
