Ironhead A place to talk about Ironheads.
No compression
Old Sep 24, 2024 | 08:37 AM
Racepres's Avatar
Racepres
Originally Posted by Abilyeu
Definitely! This is the third old sporty I’ve had they’ve all had issues but never compression
BTW, Oiling for second compression test, is to help Identify Rings vs Valves... betting little to No Difference on yours. As I suspect Valve(s)
Old Sep 25, 2024 | 02:10 PM
Abilyeu's Avatar
Abilyeu
yeah I’m thinking the same but I’ll get it apart soon and figure out what the issue is thanks!
Old Sep 26, 2024 | 07:51 AM
The Doctor71's Avatar
The Doctor71
A few meaningless observations, in no particular order:
  • it's tougher than you think to get a high compression reading on a '71 xlch. Why ? One can only kick so hard / fast. Your leg is not as good as an electric starter.
  • a 90 PSI reading isn't all that bad on the front cyl, given it's a kicker. If electric start, then 90 is very poor.
  • a 30 PSI reading is definitely bad on the rear cyl
  • why have the key "ON" during a compression test ? Just leave it "off". (I think yours is a kick only bike)
  • thottle & choke BOTH wide open
  • BOTH plugs should be out when doing a compression test. aka when testing the rear cyl, the plug in the front cyl should be out. Makes kicking easier for you.
  • a "leak down" test would be good too. But not all of us have the tools to do so. I get it. That said, you'll find it's difficult to get & KEEP both valves closed during a leak down test.... my fix for that is just remove the push rods.
Carry on.
Old Sep 28, 2024 | 07:30 PM
Abilyeu's Avatar
Abilyeu
Carry on.
for sure! I didn’t do the leak down test but I pulled the heads and put some gas in the valves to see if it leaks and it’s definitely leaking but I think through the guide the springs and stuff were soaked and when I took off the bolts and exhaust on the rear cylinder there was oil all over the gasket was ripped as well
Petznick
EVO
Jul 23, 2023 05:51 PM
Adam76
Engine Mechanical Topics
98
Jun 11, 2022 07:36 PM
stevequad
Exhaust System Topics
Dec 19, 2012 04:58 PM
ReapersWG
EVO
Oct 20, 2012 03:50 PM
bluechiphank
Shovelhead
May 30, 2009 10:11 PM
