Ironhead A place to talk about Ironheads.
adding front brakes
Old Apr 5, 2008 | 09:51 PM
straydog13's Avatar
straydog13
Default adding front brakes
i have spoke rims.i am just unsure of the best way to add front brakes.the bike already has hand controls i am just wondering the best way/any way to add a rotor or do i need to find another rim to be able to have front brakes?--thanks in advance.
Old Apr 7, 2008 | 10:03 PM
nemesistech's Avatar
nemesistech
Default RE: adding front brakes
If it is just a spool rim, yes. The rim will have to have a flange on it to mount the rotor to.
Also your forks will need some sort of attachment point as well, going to depend on what
type of caliper/ brake set up you use.
Also make sure you have clearance between the forks to add a caliper/axle bracket, I have seen
very narrow front ends that didnt have the clearance to add a bracket.
Old Apr 10, 2008 | 04:29 AM
Hopper's Avatar
Hopper
Just rub your boot on the front tyre as you ride along.
That works about as good as the stock Ironhead front brakes ever did.
misfitJason
Mar 20, 2019 12:46 AM
vanillapricea
Wheels/Tires
Jul 15, 2018 06:41 PM
langwilliams
EVO
Apr 30, 2016 06:22 PM
Housegoat
Mar 12, 2015 06:49 PM
MILLER41143
Aug 12, 2011 11:43 PM
