Ironhead A place to talk about Ironheads.
Bore and Stroker kits
Old Feb 12, 2006 | 07:27 PM
SKJOLD's Avatar
SKJOLD
Default Bore and Stroker kits
Does anyone know of any after market big bore or stroker kits for Ironhead engines? Has anyone here stroked one out? I know the stock stroke is 3.8125 inches. How much more can one go without sacrificing reliability? Increasing the bore size would not add as much stress as stroking but I have yet to find a big bore kit for one.
Old Feb 12, 2006 | 09:43 PM
pococj's Avatar
pococj
Default RE: Bore and Stroker kits
Have you checked with the dudes at http://www.sportster.org/home.html
Old Mar 3, 2006 | 11:57 AM
strokersteve's Avatar
strokersteve
HI. I run a 79 1280 stroker sportster, and have had many others. The whole stroker thing is out of hand. Its not Rocket science. Its putting a longer stroke into your motor, whoopie. Contact the "Dragon man" look him up on your search engine. He builds motors, the best, period, bar nome.
call him, discuss what you want, and send him your motor. He will do it all and not emty your bank account. He's got an add in just about every chopper rag out there.
Old Mar 4, 2006 | 02:16 AM
pococj's Avatar
pococj
ORIGINAL: strokersteve
Steve, have you had good experiences with the Dragon Man? Just wondering because on several other forums there were numerous complaints about him, from the quality of his work, to having parts swapped out with someone else's stuff, to not getting stuff returned in a timely manne, and probaly a few more. And while there have been a few who had good results, they seemed to be the minority.
This isn't meant as an attack on you, or even on the Dragon Man, just wanting to know your experiences.
Old Mar 4, 2006 | 02:19 PM
Y2K's Avatar
Y2K
I had an 86" '75 Ironhead via Truett & Osborn lower end and Axtell top end.
Much machining required on the cases and I had 12:1 pistons with high lift cams and Baisley heads with oversized valves so some machining on the psitons was also required.
I wouldn't recomend a build like this for a daily rider though,bad *** yes but tempermental and hard to start.
A lower compression less cam'd up version could be doable for a daily rider.
Looky here
http://www.truettandosborn.com/
http://www.axtellsales.com/
Old Mar 4, 2006 | 05:42 PM
strokersteve
HI, Dragon Man, as like others, get bad press. I personaly dont know why, he's done 2 motors for me. run strong and true, thanks.
Old Apr 29, 2006 | 01:49 AM
SKJOLD's Avatar
SKJOLD
I am looking at getting 75CI displacement. .30 overbore and 4 and 3/4 inch stroke. Is that too much for a daily driver or long distance cruiser?
Brownshoe 2012 FLHX
General Topics/Tech Tips
Apr 25, 2015 07:16 AM
FL-kruzen
EVO
11
Oct 23, 2012 05:20 AM
crazy_walt
Jul 10, 2011 06:10 PM
yandeltx
Mar 5, 2010 11:29 PM
jeffwest5599
May 30, 2008 08:03 PM
