New Pistons
Old Oct 18, 2012 | 04:40 PM
FL-kruzen's Avatar
FL-kruzen
Default New Pistons
I looking at big bore kits, and seen two different pistons. Most I've seen are flat top and some are domed top. Does anyone know what the difference is and what is the best to use?
Thanks
Mark
Old Oct 18, 2012 | 06:50 PM
Spanners39's Avatar
Spanners39
No such thing as a big bore kit for an Evo, stroker kits are the only way to properly increase cubes....you can bore the cases and get fancy with bigger cubes that way but it ain't no kit, its a totally different scenario.
Some of the "Big Bore kits" for Evos are merely the largest rebore size available and the increase in cubes is insignificant......unless you ride a Sportster, in which case the answer to your question will be much longer.
Old Oct 18, 2012 | 07:35 PM
1997bagger's Avatar
1997bagger
Strokin it is the only way to go, if you convince yourself of a larger cylinder setup you usually have to have the crank balanced anyway and remember one thing, say no to Revolution Performance Nika-sil
If you are dead set on a big bore then Axtell is your answer. 97" with a stock crank and 106" with a 4 5/8 arm. The 97" stock cased Harley engine has been around for a while but stressing the cases with the spigot overbore
Revolution Performance a large overbore aluminum jug with nickel material coated cylinder walls
Axtell is a cast iron jug with steel cylinder wall that is tougher than puttin a wet noodle in a wildcats a$$ but heavy in weight
Sputhe has something
S&S is setup for a 96" with a 4 5/8 arm
Old Oct 19, 2012 | 05:32 AM
grbrown's Avatar
grbrown
I looked into converting my stroker to yet bigger, by boring the cases. I soon realised that was not wise so costed for new cases. I seem to recall Axtell and Sputhe made suitable new strong cases, but the total cost was getting silly. A new S&S motor was even more, but built like a Sherman tank! I just wish I had gone even bigger than my cute little 107"....
Further to what Spanners said, our 80" Evos are actually around 82" stock, and every rebore size adds approximately 1", so an 85" kit is simply max oversize, with high comp pistons. If you want to really gee up your ride contact HDF sponsors Hillside Cycle. There must also be a decent tuning shop or two near you?
Old Oct 19, 2012 | 07:01 AM
miacycles's Avatar
miacycles
Take a look at Ultima's short blocks, or perhaps a complete engine. If you sell your old engine then they become very reasonable.
John
Old Oct 19, 2012 | 10:20 AM
jokenroll's Avatar
jokenroll
Was strongly suggested against strokin an evo by a local dealership guru (whom I do trust).
Had a big bore kit before, where you have to bore the cases - total crap, sleeves get warped coz they are too thin, starts sucking oil, no possibility for reboring (again coz the sleeves are too thin).
The only sound way to sup-up an evo, imho, would be head porting and higher compression pistons. May also look at Edelbrok or S&S heads...
My 2 cents
Old Oct 19, 2012 | 01:28 PM
FL-kruzen's Avatar
FL-kruzen
Sorry for the confusion folks, I have a 2001 FLHTC TC-88
Old Oct 19, 2012 | 05:54 PM
miacycles's Avatar
miacycles
OK then there are "big bore" kits for that. Stick wit the flat top pistons as the larger bore will increase the C/R by itself. Higher compression will give you more power, but with fuel not getting any better it may not be the way to go with an every day rider. Additionally to get scientific for a minute "Flat top pistons allow for the propagation of the flame front, thereby getting more efficency out of the engine".
John
Old Oct 20, 2012 | 06:20 AM
1997bagger's Avatar
1997bagger
John
In addtion to John's scientific views, flat tops won't create hot spots like domes from flame travel that can lead to detonation or piston damage.
Would like to hear more on why someone would advise against putting a 4 5/8 stroker kit in a Evo case, straight install - no clearancing, no spigot problems, one disadvantage is more piston speed is created for a possible cylinder wear factor but not that big of deal. I know that more stroke creates more torque and in a big bike is the answer, big bores can't create torque from a mechanical advantage like a longer armed crank and he with the most cubes wins in a natural aspirated environment.
Old Oct 20, 2012 | 03:53 PM
Spanners39's Avatar
Spanners39
Stroker kits tend to use oil and have some interesting piston speeds...but boy oh boy are they fun to ride!!!! I look after an FXR with an S&S Stroker kit....I look forward to seeing it and nearly try to buy it off the guy every time I ride it :-)
