Ironhead A place to talk about Ironheads.
basketcase problems
Old Aug 3, 2008 | 08:39 PM
68sportster's Avatar
68sportster
Stage III
Default basketcase problems
just bought a 68 sportster and am haveing problems getting it running good replaced the timing advance springs got it to idle nice but it would pop out of the carbs at speed re adjusted carbs timing it ran good at speed but when you stop it dies and wont idle i was told this motor and carb have been worked on = punched .030 over p cams carb was jetted and bored pulled plugs and they were full of carbon and gapped at .070 not sure what gap should be but this seems large does anybody know what plugs i should run and what gap any info is greatly appriceated thanks for the help
Old Aug 4, 2008 | 12:37 AM
FilthyLucre's Avatar
FilthyLucre
Default RE: basketcase problems
Plug gap should be between .025 and .030 Harley number 5 was standard, I believe the NGK equivalent was B6L, Champion H8, Autolite ATL4.
Old Aug 4, 2008 | 03:20 PM
fergerburger's Avatar
fergerburger
check your push rods...I'll bet they are tight....
Old Aug 4, 2008 | 05:03 PM
68sportster
Stage III
push rods are correctly adjusted im sure its plugs they were gapped so big that it melted the porcalin on the electrode
thanks for the numbers going to get no plugs and try them out
jaycafe
Exhaust System Topics
Aug 18, 2011 09:25 AM
rounder
May 18, 2010 05:23 PM
gpaxtell
Ironhead
13
Jun 22, 2009 07:05 AM
adubb1
Apr 7, 2008 04:51 PM
B Will
Apr 7, 2008 12:19 PM
