Ironhead A place to talk about Ironheads.
hi and low idle
Old Sep 19, 2008 | 04:45 PM
98glider's Avatar
98glider
Default hi and low idle
I have a s&s e carb on my 84 ironhead I just noticed that the idle stays up a little then goes down when I come to a stop only when she is hot . It seems that the throttle cable is tight but I lossen ed them both up and she still does it. Now the bike doesn't race up like she is going to blow she just seems that she idles a little high checked the throttle screw and she is coming back to the idle screw any help Thanks
Old Sep 19, 2008 | 08:36 PM
240vtx's Avatar
240vtx
hi thats a low idle.
Old Sep 20, 2008 | 12:42 AM
irondude's Avatar
irondude
adjust idle screw with the bike hot, check for intake leak.
Old Sep 20, 2008 | 09:12 AM
sqdealgeorge's Avatar
sqdealgeorge
Are you supporting the carb off the engine ?
Old Sep 20, 2008 | 11:03 AM
98glider's Avatar
98glider
The plugs look good for the intake leak but didnot check for keaks what is the best possible for this. and the carb is not supported off the engine. Thanks
Old Sep 20, 2008 | 12:44 PM
irondude's Avatar
irondude
You have to get the support on there. It vibrates way to much without it, loosening the intake seal. While idling, spray carb cleaner around the intake rubbers to check for leaks. If the idle changes when you spray, you got a leak. Also, pull up the enrichener while idling. If it dies, that's a good indication of a leak.
Old Sep 20, 2008 | 01:26 PM
98glider's Avatar
98glider
I'm sorry there is a bracket on the carb my mistake I will check the intake
Old Sep 20, 2008 | 01:28 PM
98glider's Avatar
98glider
it has a bracket to the motor
RollingBurn
Apr 13, 2015 06:25 PM
Maui
Jul 20, 2014 08:50 AM
XL1250
Jul 21, 2012 06:17 AM
2002 KING
Exhaust System Topics
Dec 8, 2008 09:46 AM
robjohnston
Dec 8, 2006 07:45 PM
