Ironhead A place to talk about Ironheads.
Correct way to remove and install right-side engine cover?
Old Oct 27, 2008 | 07:24 PM
Ludeykrus's Avatar
Ludeykrus
Default Correct way to remove and install right-side engine cover?
Howdy,
First, is there a correct way to remove the right side engine cover on my '77 without pulling out any gears? I've had to pull that cover a few times now and the gears come out with it every single time....
Second, is there a correct way to reinstall it? It does not slide right on at all, takes a lot of finaggling. Is this something that needs to be tapped on with a rubber mallet to get it on? I mean it's a TIGHT fit!
Thanks,
Ludeykrus
Old Oct 27, 2008 | 10:48 PM
piniongear's Avatar
piniongear
Originally Posted by Ludeykrus
Howdy,
Thanks,
Ludeykrus
Some guys will lay the bike over on the left side and hope and pray the cams and shims don't fall out when they pull the cover.
I have never tried that myself, maybe because cams falling out does not bother me at all.
When you install the cover, you are having to line up 4 camshafts. a piniongear shaft, an idle gear shaft, and a couple of dowell pins.....all at once! So it's no wonder the cover is a bit difficult to get back on.
And NO, do not tap anything with a rubber hammer.
I hope you have the push rods removed when you re-install the cover?
Likewise when you remove the cover.
If that is not the case, then you have some of the valve springs pushing the cams downward and this makes it almost impossible to get all of the shafts lined up. So maybe that is the problem causing the installation of the cover to be a challenge?
pg
Old Oct 28, 2008 | 09:55 AM
d_slat's Avatar
d_slat
I haven't tried it yet, but I read somewhere on here that if you lay the bike on it's side and leave the pushrods alone when you disassemble , if you give the cover a tap with a plastic mallet right before you lift it off, it will help stick the shims to the cams and allow you to remove the cover w/o dropping everything. Just make sure to loosen the pushrods for re-installing the cover.
Old Oct 29, 2008 | 06:27 AM
sepixlh's Avatar
sepixlh
Cool
This can be done only if you have drinked 1 gallon of whiskey forehand and you are not passed out yet... Seriously... remove push rods before camcover it's much easier and you don't damage cams !
Old Nov 1, 2008 | 08:00 PM
straydog13's Avatar
straydog13
i just did this and i wasnt looking forward to it but for me it went good.basically everything that was said above and i did tap on it BEFORE i took it off with a rubber mallet...did it help?i really dunno but it didnt hurt.i would not tap on it at all to get it back on.i rolled it an took pressure off 2 of the push rods and loosened the others.that is really the key.no cams came out.my bike also leans waay over so that no doubt helped...you might find a way so your bike does that .i cant imagine laying my bike on the ground on purpose for anything though ....that is some serious cam hatred there imo.
ludakris that is a very wicked bike you got there...
Old Nov 5, 2008 | 11:42 AM
Ludeykrus's Avatar
Ludeykrus
Thanks Stray, I appreciate it!
I do believe that my problem lies in the loosening of the pushrods before reinstalling. Thanks all! We'll see how it goes this next time....
badknees
Apr 20, 2023 04:06 PM
JohnJohnson
Oct 21, 2015 11:42 AM
cmstewart72
Jan 3, 2014 08:41 AM
Guardguy86
Jan 9, 2012 05:17 PM
greg3131
Oct 14, 2007 08:36 PM
