Ironhead A place to talk about Ironheads.
Primary and engine oil confusion
Old May 22, 2009 | 04:55 PM
AmericanNightmare73's Avatar
AmericanNightmare73
I'm running Rev Tech 70w in engine and Rev Tech's High Performance Gear and Chaincase Lube for Sportsters in the Tranny
Old May 23, 2009 | 12:41 PM
pococj's Avatar
pococj
Originally Posted by straydog13
80w???? are you sure about that?
That is a gear oil recommendation. 80w gear oil is about equal to mid 20 thru mid 30 weight engine oil.
Old May 29, 2009 | 06:26 PM
straydog13's Avatar
straydog13
are you saying 80w gear oil is the same as 30w engine oil?if you had a cup of each you couldnt tell the difference???----------i dont understand...i am not sure what i am missing.
Old May 29, 2009 | 09:34 PM
IronMick's Avatar
IronMick
The weight numbers for gear oil are not the same as the weight numbers for engine oil. I personally do not know what they represent or how they are determined, just that they are not the same.
Old May 30, 2009 | 11:55 AM
straydog13's Avatar
straydog13
i honestly never knew that.i always assumed(theres that word again..) that it was the same rating system.i understand there was most likely different additives for a gear oil compared to an engine oil but i always thought the weight of it would be on the same scale.
Old May 31, 2009 | 09:08 AM
98glider's Avatar
98glider
I have a early 84 with a gen and harley sugg. 50wt and sportster tranny fluid manual says just heavy motor oil
jamesandthejet
EVO
13
May 15, 2018 09:06 PM
JayLo
Mar 29, 2014 07:54 AM
FastHoss
Ironhead
Oct 12, 2009 08:13 PM
peewee97
Ironhead
May 22, 2008 08:12 AM
jim6tseven
Ironhead
Aug 17, 2007 12:33 AM
