can anyone tell me where the speedo connects to on a 67 xlch, not sure whether its off the transmission or the front wheel. i cant seem to find anything in the manual that tells me one or the other. thanks.
First, it most certainly does not connect to the front wheel.
You are going to find the connection located under the kick start/counter shaft sprocket side cover.
If you get under the bike you can see the speedometer mount on the right side/front of the transmission case just behind the oil pump.
This item has never been shown or discussed in any factory service manual........ pg
