Ironhead A place to talk about Ironheads.
primary chain
Old Jul 13, 2009 | 07:22 AM
98glider's Avatar
98glider
Default primary chain
Is it better to adjust hot or cold. Also when do you know when she has been stretched out no more adjustment I have a early 84 ironhead mileage is unknown
Old Jul 13, 2009 | 10:07 AM
d_slat's Avatar
d_slat
they give specs for both, so it prolly doesnt matter. I usually set mine cold because it's easier for me.
Old Jul 13, 2009 | 07:19 PM
IronMick's Avatar
IronMick
I usually set mine up cold and check it later hot, just to see the difference.
I have been told reliably that the primary chains are unlikely to wear out, partly because they run in oil. I suppose an abused one would need to be replaced. If it will take the adjustment i expect that it is good.
Old Jul 13, 2009 | 08:16 PM
98glider's Avatar
98glider
I 'll try when she is cold thanks
Old Jul 13, 2009 | 08:56 PM
bustert's Avatar
bustert
primary chain cold is 5/8 to 7/8 inch slack and hot is 3/8 to 5/8 inches slack. i check mine cold. there is an adjustment in the primary to take up the slack and i have yet to run out of adjustment. i find a lot of play comes from the nylon shoe wearing out. i have heard of a hydraulic adjuster that will do away with the shoe but i have never really persued the idea. i believe i have changed three shoes in 150 k miles so is it really worth the hydraulics? can they break? never say never!! i have seen so really bad chains due to poor maintenance. a couple of signs to look for is the teeth becoming sharp and the rollers on the links starting to crack. same goes for the rear chain.
Old Jul 14, 2009 | 06:21 AM
98glider's Avatar
98glider
When you check the slack do you measure center to center? the manual says to check cold or hot and gives the spec. thanks
Old Jul 14, 2009 | 03:52 PM
IronMick's Avatar
IronMick
I lift the top row up with a screwdriver or wrench or whatever, and estimate the amount of movement. Some guys use a 1/2" open end wrench to measure. Since the chain is a little less then 1/2" thick i judge it to be OK when hot if the bottom goes up just past where the top was.
long_overdue
Shovelhead
Jul 6, 2018 02:00 AM
harleyglen
Apr 2, 2015 07:47 AM
Rastus
11
Oct 3, 2007 07:02 AM
OneBlackFly
Sep 3, 2007 08:16 PM
bikerbehaviorist
Jun 16, 2007 04:44 PM
