Lotsa pressure
Thanks for the print! Did that come from the manual? And thanks for the clarification on the degree of importance at this point. Everything went back together smoothly last night. Tonight I'll get the lash set and hopefully get 'er timed! This s@#t is too much fun!
Yes, right from the manual.
You got what you got regarding the valve seat facing job.
As long as you have good compression and the pushrods went back in you are in good shape. Don't worry about the valve seats.
pg
Thanks!
pg
the pushrod can be turned by pulling across it with one finger.
there is no up and down play
there is no side to side play.
After thinking a bit about my earlier question, I came to the conclusion(which may very well be wrong) that if I have to use my thumb and forefinger to turn the pushrod, there may be enough pressure to start moving the valve. Even if it's only .001 it , it has moved .001. On the other side of the coin, I'm sure there is at least that much movement, if not more, clearance built in to groove in the valve stem where the keeper/lock sets in. Soooo, which one of my cockamamie theories is more likely?
6. Check [and adjust if necessary] the push rods:
[a] using the rear wheel rotate the engine so that the rear cylinder exhaust push rod tappet is fully raised. The front cylinder push rod is adjusted correctly if it has no vertical or horizontal play, and you can just rotate the push rod between thumb and forefinger with no trace of binding or dragging.
[b] to adjust if needed: hold the adjusting screw in place with a wrench; with another wrench loosen the split locknut. Then turn the adjusting screw using fingers only until the pushrod's ball end is seated in the tappet with a "slight amount of play". Then tighten further as follows:
Option 1: Adjust on the tighter end of the range: There should be no vertical or horizontal play, and you should be just able to rotate the push rod between thumb and forefinger with no trace of binding or dragging.
Option 2: Adjust on the looser end of the range: Set the adjusting screw to finger tight so that you cannot turn the push rod between forefinger and thumb. Undo it a tiny bit so that it is just barely loose. Then loosen it 1 "side" for an exhaust or 1/2 "side" for an intake. "Side" refers to one side of the 6-sided adjusting nut.
EDIT: My experience and that of several others who have tried it is that Option 2 is the better and most likely the correct choice.
One finger only to turn the pushrod.
Just like the mock up I did earlier with a screwdriver. That is how you determine the adjustment.
This adjustment is either just right or it is not.
Many times I have had to re-adjust over and over again to get it right.
And having a lot of experience does not make it any easier either.
pg
pg
Is the carb pulling enough air to utilize the main jet when quickly twisting the throttle?
Should I try turning the main jet in?
Would the fact that I have only static timed it cause this?
Could it be my fancy shmancy Taiwanese points?
All in all, it did better than it did before so we are making progress.
Oh, and guess what! no oil leaks! Oops probably shouldn't have said that.
Hopefully some day I'll be able to help someone else like you guys have helped me.
Thanks!
It sounds like something is hanging up in the float. The problem to look for is something causing the needle to fail to seat.
When a bump with a wrench lets the needle find home there is some small thing causing this. One example is..... suppose an edge of a float bowl gasket were to catch the side of the float. This could hold the float from rising and the bump would jar it loose.
Now, I am not suggesting this is the problem because I do not think it is but given only as an example of what could happen.
So look at the float parts carefully. It should not ever hang.
Pulled the plugs, dried 'em off, and prepared again. Three kicks and she fired up. It ran REALLY rich at an idle, and eventually fouled the plugs. All black and almost furry looking. Cleaned them off...again, turned in the idle mixture screw 1/4 turn and it did better. If I try goosing it, it still falls on its face and when I roll on to it a little more (but not much more) gently, it misses and shoots flames out of the pipes. Tomorrow I'm going to turn in the idle mixture screw another 1/8 turn or so and change the plugs and wires. The wires on there are as old as the top end rebuild. (low miles but a lot of time) and those plugs have probably been fouled 30 times now. I never checked the numbers on my main jet.
The only thing regarding the main jet causing the rich condition at low speed (idling) is if that O ring were leaking fuel into the venturi. You said you had a new O ring though, if I recall correctly. See below.
If the plugs are soot fouling the fuel mixture is too heavy on fuel or too light on air. The main jet does not come into play until approx. ź throttle and up to wide open. So I do not think the main jet is an issue yet. We are talking about idling speed (unless I missed something). The problem is in the low speed circuit.
After changing the plugs and wires out, start it up and see if it will idle smoothly.
After it has warmed up and with the choke off try turning the low speed needle inward and pay attention to the idle speed. This will lean the mixture. If the idle speed increases while you are doing the adjustment.......stop turning the mixture screw and readjust the idle speed down to around 900 rpm. Then resume the adjustment.
The reason for this is because as the idle speed increases over normal, different parts of the carb come into play which will affect the low speed adjustment we are working on here. So try to keep the idle speed at 900 to 1000 rpm.
When it falters, stop turning the screw.
Turn the screw outward to enrich the mixture. The smooth speed should appear again. keep turning the screw out until the engine falters. Stop. (You may have to readjust the idle speed as you do this step as well, if it gets over 1000 rpm.)
Now turn the screw back in to the mid point between the two extremes. This is a perfect low speed adjustment, and there is nothing left to do on the carb adjustment at this point regarding the low speed adjustment. Adjust the idle speed to 900 rpm if needed.
Should I try turning the main jet in? No. See above.
Would the fact that I have only static timed it cause this? It is most likely the reason for the backfiring. The only other thing that can cause backfire is an air leak in the inlet manifold O rings. If you have an air leak there, most likely it will not idle smoothly, nor respond to the throttle blip.
Could it be my fancy shmancy Taiwanese points? If they are new, or in good condition and line up with the proper gap set..... the answer is No.
All in all, it did better than it did before so we are making progress. You certainly are! And learning as you go, which is the best way.
When an Ironhead does not leak at all, I want to buy the first ticket to the show!
Thanks!
New plugs and wires will be good to use, but don't expect those to solve the problem.
Richness is the result of an imbalance of the fuel/air mix.
The backfiring may be a timing (lack of proper timing) or an air leak in the manifold O rings. For now let's assume it is a timing issue.
Keep us posted.
pg
One thing I did encounter was having a bit of trouble getting the idle to stay below 1200 RPM's. After looking a little closer , I noticed that my idle speed adjustment screw wasn't touching the ear on the throttle shaft. The butterfly must not be perfectly centered. Oh, well I wanted to pull the carb anyway to inspect the float and everything for any reasons it may be hanging up. I also wanted to lock tight the screws in the throttle and choke plate as well. I'd really rather not suck one of those babies into the intake!
Something else that may be noteworthy. In light of pushrod adjustment last night , I was listening extra close for lifter clatter or the pushrods bouncing around between the rockers and lifter. I heard something possibly similar. Put my ear to the covers and then realized that it was coming from inside the carb. I think what I was hearing was the valves closing. Could this be? I didn't hear it before the adjustment. I think I'm glad I hear it. Little concerned as well.
Thanks again for all the help. Otherwise , I may have given in, heeded all the locals advice and taken it out to Roberson's ( a shop about 45 min. away that works on mainly shovels). Then the next time I had an issue, I'd have to load it up and take it back again, that is if they would even work on an Ironhead. The help and in depth explanations are truly priceless. They have made me understand and appreciate this old bike even more. As I said before, it's all starting to make sense.
