Ironhead A place to talk about Ironheads.
flasher wiring
Old Nov 4, 2009 | 02:31 PM
popstheoldman's Avatar
popstheoldman
Question flasher wiring
in factory manual it shows 2 green wires going to the flasher from the left and right handlebar switchs.then it shows only one green wire going to the flasher but coming from something like could be a 3way tap? it doesnt say.anybody with some info on this
thanx
Old Nov 4, 2009 | 05:00 PM
IronMick's Avatar
IronMick
Originally Posted by popstheoldman
in factory manual it shows 2 green wires going to the flasher from the left and right handlebar switchs.then it shows only one green wire going to the flasher but coming from something like could be a 3way tap? ...
There is an orange and a green wire going to the flasher. All of the orange wires on the bike are always 12 volts with the key on. The one green is a combination of one from each handlebar switch - combined at a junction.
After that it gets too complicated for me. Follow the wires back from the lights. They join up in a headlite connector.
Old Nov 4, 2009 | 08:14 PM
nwpaironhead's Avatar
nwpaironhead
...then it shows only one green wire going to the flasher but coming from something like could be a 3way tap?
thanx[/quote]
I think what you're seeing is item number 35? My manual is from 70 to 78. In my manual, item number is just a simple connector. I just ran both wires to a female spade plug and crimped them both in. I suppose you could run both wires into a butt connector , then run one lead to the flasher, or solder and heat shrink them. I was trying to limit my number of connections(chances for failure) . That was why I ran them both to the female crimp on plug.
Old Nov 4, 2009 | 09:49 PM
popstheoldman
ok thanx everyone now one more question does an 82 sporty use a turn signal module?
to turn on or off? or do i just hold the button down?
Old Nov 4, 2009 | 11:47 PM
sepixlh's Avatar
sepixlh
That turn signal module came 1991...
Old Nov 5, 2009 | 10:57 AM
popstheoldman
ok thank you everyone
jqb12
Feb 10, 2017 08:35 PM
Randy Marsh
Mar 27, 2015 07:07 AM
PJGoose69
Oct 1, 2013 01:19 PM
scooter1976
Jul 26, 2012 12:29 PM
SC-Longhair
Oct 14, 2008 12:39 PM
