Ironhead A place to talk about Ironheads.
Primary oil leak
Old Feb 15, 2010 | 04:38 PM
bennenrkc's Avatar
bennenrkc
Default Primary oil leak
When I start my 1974 XLH it starts to pump oil out of the oil fill plug on the primary. Any ideas as to what causes this and what I can do to fix it.
The plug is tight but the breather hole in the middle of the plug is where the oil is running out. Also the oil inside the primary is at the appropriate height and the oil in the oil tank was low when I shut the bike off.
Old Feb 15, 2010 | 06:31 PM
IronMick's Avatar
IronMick
Originally Posted by bennenrkc
...the oil inside the primary is at the appropriate height ...
Do you use the overflow hole to determine this?
Old Feb 15, 2010 | 07:20 PM
piniongear's Avatar
piniongear
You say the primary/transmission oil level is correct but yet it........
(1) Blows oil out the vent hole in the filler cap, and...
(2) The oil level in the oil tank was low after sitting awhile?
I say the oil level inside the primary and trans is too high.
If the bike sat for a bit without being cranked up then what has happened is the oil leaked past the check valve in the oil pump. This removed oil from the tank.
The oil drained through the pump by gravity and collected in the engine lower end.
After that, the oil ran from the sump into the primary cover (you did have the bike on the side stand while it sat without being cranked didn't you?) The sump oil drained through the transfer valve into the primary and then into the transmission.
The fix:
Drain the oil from both the primary and the transmission by removing both drain plugs.
Replace the plugs and fill the primary and transmission with 24oz of engine oil. That should cure the problem. And yeah, crank up the bike more often to keep the oil from leaking down into the lower end.
pg
Old Jun 18, 2014 | 10:32 AM
sephus's Avatar
sephus
Stage I
I realize that this is an old thread or whatever, but, I just went through this exact situation. If this is happening to you it is most likely your crank shaft seal is either not seated, or needs to be replaced. The seal is allowing not only crank case oil to blow by, but also the compression that is created by your pistons coming down. Thus creating pressure in your primary case and blowing oil out of the vent hole in the oil fill plug. I assume because there is near equal pressure at both the crank shaft seal and the vent hole in the fill plug the exchange rate is the same. I do know that although I had oil pumping out of my primary the level of the oil inside of it remained correct. I hope this helps. Ride safe.
300sd1982
EVO
Jun 21, 2017 08:48 PM
duallram03
EVO
Oct 13, 2013 08:19 PM
hdjimi
Sep 11, 2009 12:47 AM
pitbull1
Ironhead
Oct 17, 2008 08:48 AM
sharkie
Classic
13
Nov 5, 2005 05:44 PM
