1978 Refurbish Complete - Video
YouTube- 1978 Sportster 75th Anniversary Edition
The details ...
1978 75th Anniversary IronHead, Refurbish Complete ...
Part 1: Fall 2009 Project - Get It Running
top end rebuild: .030 over, Wiseco pistons, 1000 mile break-in complete
Ultima electronic ignition, single fire
new forward controls, new oil and fuel lines properly routed, K&N air filter
replaced fork seals, oil pressure switch, battery, regulator, solenoid
lubricated cables
Part 2: Winter 2009/2010 Project
gold wheels refurbished
hand painted frame, swing arm, battery box, horn, start relay
drilled and painted air cleaner back plate
cleaned up forks, shocks, tach & speedo, electrical
refurbished carburetor, generator, starter motor, brake calipers, rear brake system, rebuilt brake master cylinder
replaced speedo drive & cable, brake rotors, rear brake cable, generator lite, run switch
replaced shock mount hardware & rubber bushings, rubber mounts for oil tank/battery box
new headlite visor, oil cooler by-pass, petcock for king tank
freed up sticky choke wire
from my old bike: handlebar mounted voltmeter, sissy bar bag, Tim Horton's coffee cup holder, running lights, center stand, windscreen, Sportster mirrors
Mike's Cycle Seats finished minor repair, and a modification to make it more comfortable
Harley tall eagle wing emblem for the sissy bar golded and installed.
Part 3:
Kicker Kit done with all parts OEM NOS except the arm and pedal
Part 4: Paint Etc
Re-striping the fenders, decals and stripes for the king gas tank and oil tank.
Decals for the air cleaner, primary cover, brake calipers, battery box, and front fork installed. Some of these are OEM NOS parts, others are re-pops.
Part 5: TuneUp and ShakeDown Runs
Finalized the tuneup: 180 main jet, 75 slow jet, 1 turn out on pilot screw, 35` ignition timing.
Part 6: Spring 2010
Honda GB500 fork gaiters, pull back risers, old style fork caps and instrument mounts, new handlebar bushings, re-configured handlebar switch cables
New brake shoes and rear tire; rear wheel centered to fit the wider brand of 120 tire
The indie had a nice, used carry rack. Now mine. With tool bag.
New Cycle Shack taper tip mufflers for 1980 to 2003 fitted
Chrome tail light cover installed, broken chain guard re-welded
#1 decals installed
Part 7: Not In The Plan
Polishing up all the aluminum so it looks like chrome. But never say never. My indie will do it for a very reasonable price. I'll consider it when the parts have to be off for some other reason anyway.
Unless you have your own machine shop and are an expert machinist, this is the way to go. You need a place to work, a methodical approach, and a few special tools such as a piston ring compressor etc, but there is no need to pay a shop guy $50 to $100 per hour to undo and redo nuts and bolts.
You can order a kit specifically for 1979 from any of the catalog companies such as J&P Cycles. If you decide to do this ask me using a PM and i will pass on more helpful information.
