Ironhead A place to talk about Ironheads.
Wide Glide frontend
Old Jun 2, 2010 | 05:06 PM
70Weight's Avatar
70Weight
T-Ron,
What happened was I bought the Santee frame for early Ironheads,57-76.
It came with the 7/8" neck,Then,without thinking I bought the custom wide glide front end..get home with this stuff then figured out what I did(I'm old)
So,rather than take back the front end,I used a 1" reamer and made the front fit...The Santee has plenty meat to do this,a stock frame I dont know.Thats better left for experts to decide..I aint one! But I think theres cups You can buy to use a 1" front using the 7/8" neck.I will google it to see what I can find.
Old Jun 2, 2010 | 05:09 PM
70Weight's Avatar
70Weight
Originally Posted by shepdog
you could try the lighter fork oil, my local shop sells a light and a heavy fork oil, both are from harley maybe look into a lighter spring?
Thanks Shep..theres 30wt in it now..15wt getting put in soon.
Old Jun 2, 2010 | 07:24 PM
IronMick's Avatar
IronMick
I have never before this heard of using 30Wt fork oil. 15Wt is considered heavy. Many guys use 5W.
Old Jun 2, 2010 | 07:38 PM
shepdog's Avatar
shepdog
i went out and checked my bottle of harley fork oil, it only says type "e" on it, was told by the local dealer it was the heavier oil, does not say what wt it is
Old Jun 2, 2010 | 08:25 PM
70Weight's Avatar
70Weight
This stuffs made by PG1 it does say 30wt on it,called "Tuner oil" heavy.
I believe its my problem..going to try the 15wt
Old Jun 2, 2010 | 08:55 PM
NSCoyote's Avatar
NSCoyote
Originally Posted by 70Weight
T-Ron,
billetwerx makes the conversion cups they allow you to use the later 1" stems on the earlier 7/8 necks. just bought a set fast shipping great guys to deal with
http://www.billetwerx.com/
Old Jun 2, 2010 | 10:36 PM
IronMick's Avatar
IronMick
I think the two HD oils are 5W and 15W. If the "e" is the heavier one then it is the 15w.
Old Jun 2, 2010 | 10:43 PM
dirty78ironhead's Avatar
dirty78ironhead
Using the billet werks cups was part of the plan but I think my plan is changing. Might end up with a frame and a new front end to go along with it. Still doing the research. We shall see!
Old Jun 3, 2010 | 07:01 PM
70Weight's Avatar
70Weight
Thanks Mick and Shep
this is where i screwed up, because the 15wt rides fine.
mturner2003
Feb 3, 2014 06:40 AM
HELDVR
Mar 19, 2009 10:58 AM
HDDYNA
Feb 18, 2009 04:26 PM
Jinxie
Feb 17, 2009 12:21 PM
wiegs
May 13, 2008 09:56 PM
