Ironhead A place to talk about Ironheads.
Brake and Ignition problems.
Old Aug 12, 2010 | 01:06 PM
Karbon's Avatar
Karbon
Default Brake and Ignition problems.
Hi there, I asked this over in the sportster section but I guess my bike is too oldskool so lets try this again.
I just picked up a 72 Ironhead did a bunch of work to it, and took it for a spin the other day (HELL YA! first ride on a Harley!) aside from having the time of my life I have a couple concerns.
The rear break sometimes grinds on itself when i apply a little break (not every time just sometimes) sounds like grinding gears in a transmission and kinda freaks this hell out of me when i'm on the highway lol.
And another thing is we wired a 3 stage ignition (same kind my dad has on his 76 shovelhead and when I turn it off the engine continues to run, I have to pop the clutch and let it die.
Old Aug 12, 2010 | 02:06 PM
IronMick's Avatar
IronMick
I would remove the rear wheel and examine all of the brake components. You definitly need the factory service manual 99484-78 for this; and preferably the parts catalog 99451-78B also.
I do not know what is meant by a 3 stage ignition - never heard the term before. Is it an electronic ignition module? Brand name?
Perhaps others can comment on the run-on after shut-off.
Old Aug 12, 2010 | 08:21 PM
Karbon's Avatar
Karbon
This is the ignition I put it (this isnt my bike) just an example.
And my old man are going to tear down the brake tomorrow.
And as for not turning off, I turn the ignition off and the bike just continues to run.
Not sure what else to say about that.
Old Aug 12, 2010 | 09:23 PM
IronMick's Avatar
IronMick
That is the ignition switch. You will have to dismantle it and check the wires. There is probably a loose or broken wire.
Old Aug 13, 2010 | 04:42 AM
sepixlh's Avatar
sepixlh
That ignition switch is for BT and has 3 positions (actually 4) , OFF, IGNITION , LIGHTS, ACCESSORY
Wireing has been done wrongly you need to check it. In accessory position you can listen radio or other useless device... without engine is running.
Normally sportsters has only 2 positions
OFF, IGNITION, LIGHTS.
Skinon
Jul 8, 2019 09:46 PM
mesmarter
EVO
11
Aug 14, 2013 06:24 PM
blueangel73
May 18, 2011 08:37 PM
JustDave71
Apr 1, 2010 12:28 PM
roofer
EVO
14
Apr 26, 2009 06:20 PM
