Ironhead A place to talk about Ironheads.
Generator Noise?
Old Aug 18, 2010 | 08:21 PM
mustangwagz's Avatar
mustangwagz
Default Generator Noise?
so got my bike all slicked up, been ridin it for a few days now. (fixed stem and bearings issue..) Runs Good, Looks great, sounds Awesome! i've noticed that i have a noise out front of engine. at first i thought maybe primary chain was loose, checked it to make sure it wasnt loose and also checked oil in case as well.
After further investigation, i think its coming from generator!? bad bearings maybe? i read manual to see what it consists of to tear it off and inspect, seems easy...just waitin for a rainy day to arrive. Something else i noticed (which leads me to think MAYBE generator) When cruising at 65, my generator light begins to glow a little bit (noticed in morning headin to work..) but if i drop er down to 60, or lower, it goes away. Whats up with that!? any thoughts? 65 mph is about 3500 rpm roughly, maybe a little closer to 4k.
How often do the bearings go bad? any input? Book doesnt seem to make it to un godly terrible to tear apart, hardest sounding part is gettin it outta the sidecase without interfeering with oil slinger?
SO whats up guys!? fill me in.. Thanks in advance too btw!
Old Aug 18, 2010 | 09:35 PM
straydog13's Avatar
straydog13
easy to get the generator out/off of the bike.----i will say this is a very common question concerning "some" noise.i dont wanna sound as if your noise is not important because it really may be......all off our noises may be i dont know but i do hear of alot people chasing a noise but i dont think anyone really ever finds it....or so it seems...good luck.i fyou do find it let us know.
Old Aug 18, 2010 | 09:42 PM
mustangwagz
ill see what i come up with and let yinz know.. Here's another questions... Can the bike be ran without the generator!? say..as for a brief moment to verify thats where noise is coming from!?
Old Aug 18, 2010 | 11:39 PM
sepixlh's Avatar
sepixlh
You can ride bike without generator but nor for very long distances, if you are NOT using lights XLH battery (32Ah) last as long as you need to refuel ( without stopping engine). XLCH battery (6Ah) I don't know. You need to cover that generator hole and protect electrical connections. Mechanical regulators, in some cases, has that kind of "feature" they act alike rev-limiter. Vibrations cause that...
Check generator asap because when armature hits to pole repairs are $$$
Old Aug 19, 2010 | 06:40 AM
IronMick's Avatar
IronMick
Originally Posted by mustangwagz
... i've noticed that i have a noise out front of engine. ... i think its coming from generator!? bad bearings maybe? ... When cruising at 65, my generator light begins to glow a little bit ... Book doesnt seem to make it to un godly terrible to tear apart, hardest sounding part is gettin it outta the sidecase without interfeering with oil slinger? ...
Probably two separate issues ...
The gen light coming on a little is probably the brushes getting stuck in the brushes holder. For this remove from bike, dismantle, clean with electrical contacts cleaner [everything!, except for the insulators under the brushes in the holder - keep all solvents away from these], measure the brushes, replace is less than 1/2".
I have three brushes holders from various gens and they all have the same condition - the insulators have expanded under the brushes so that the brushes stick. I have been told that this can be caused by various solvents. The only solution i have found [and it does work well] is to file down the brush a little until it moves freely.
The gens have two bearings, one in each end. The bearing in the outboard end is a needle bearing Timken Torrington M-881 or INA BCE89. It can be easily tapped out using an appropriate sized socket and replaced the same way. Apply a little grease - too much and it will migrate onto the commutator.
The inner end bearing is F A G 6202-ZR C3 or SKF 6202Z. A press is required to replace it although i have heard of one guy who did it at home somehow. NOTE: The forum will not allow the letters F A G to be concatenated.
The gen is about the noisiest part of the engine and it may be near impossible to make it quiet.
To remove the gen disconnect the two electrical connections, remove the two bolts from the gearcase side, tip the outer end down to 5:00 o'clock, lift the inner end up to 11:00 o'clock, and "simply" [heh heh] remove it. It may come out easily or it may require some fiddling.
It is common technique to ride without the gen to attempt to isolate the noise issue. Cover the hole with duct tape or whatever. You might try just idling with/without it first. No need to go very far, but i would run without the headlite anyway.
Old Aug 19, 2010 | 09:30 AM
83XLX's Avatar
83XLX
I'll add that the generator will make a lot more noise under load than when it's just maintaining a charge. Low battery, weak battery, overactive regulator, sometimes even running with lights will cause the gen to be more noisy for a time. If it's excessivvely noisy when all's well with the battery and charging system, then I'd look at bearings.
Old Aug 19, 2010 | 09:54 AM
IronMick's Avatar
IronMick
... and i'll add this -
IronHead Charging System Checkout
You need a multimeter. The digital ones are best and can be had for less than $10.00. A voltmeter is a multimeter set to measure DC volts. An ammeter is a multimeter set to read DC current in amps. The ohmmeter section of the multimeter will test for continuity. Continuity means that current may flow between the two points.
I find alligator clip probes are much more convenient than pointer probes. Occasionally a pointer probe is better so i have a set of each.
When using a Multimeter, if the object fails a test, repeat the test ensuring that you have good connections with the meter probes, especially to a good ground.
1. Fully charge battery.
It is not good enough to put it on a charger overnight and assume it is fully charged. Some batteries will take 24 hours to fully charge. The way to know for sure is to do a specific gravity test [for liquid filled batteries], or to use an automatic battery charger.
I have heard that you should never use a battery charger greater than 2 amps for any motorcycle; that it is best to use between .75 and 1.5 amps. Best are the automatic chargers such as Battery Minder or Battery Tender.
2A. Cell test battery [not for maintenance-free batteries].
Remove caps from battery cells. Keep the red voltmeter lead on a terminal and insert the black lead progressively into each cell, far enough that it contacts the plates. You should get readings of 2, 4, 6, 8, 10 and 12 volts. If one cell does not contribute its proper 2 volts then that cell is dead and the battery is no good.
2B. Load test battery.
It is said that, with electronic ignition, you should never crank the engine without grounded plugs attached to the wires. For this test you should install an extra set of plugs into the wires and set them onto the top cylinder head fins.
Disconnect both spark plugs. Attach voltmeter leads to the battery terminals. Crank the engine for 10 seconds [no more!]. Observe the meter WHILE cranking. If it goes below 10 volts then the battery is no good. Alternatively you can buy an expensive battery load tester.
Bring the battery up to full charge again before proceeding.
3A. Current Drain Test #1
Disconnect the battery -ve cable from the battery. Connect the ammeter between battery -ve post and the battery cable. It should read .003 amps or less.
3B. Current Drain Test #2
Disconnect the +ve terminal from the battery. Connect an automotive test light between the battery and the cable. If light comes on there is a current draw.
Note: To determine which circuit is faulty disconnect the circuit breakers or remove the fuses one at a time. When the light goes out you know which circuit is the problem.
3C. Battery Cables Test
With voltmeter connected to battery terminals check voltage while cranking. Then with voltmeter on battery cables check voltage while cranking. If voltage drop due to cranking [should not go below 10 volts] is different cables may be bad or there may be corrosion.
Here is another very simple non complex test you can do if you suspect that something is draining your battery when the key is off. This applies to bikes that have no digital instrumentation (like ironheads). Unhook your negative battery terminal. Touch the wire back to the negative battery terminal, there should be no spark when you do. If it arks and sparks (like a downed hydro pole in a rain storm in a horror movie) then something is drawing power when it shouldn't be.
4. Charging System Test
Measure the battery voltage with the bike not running. It should be at least 12.x; preferably it will be 13.x.
Measure the voltage with the bike idling at about 2000 to 3000 RPM. It should be at least 1.0 volts higher than the not-running reading, otherwise the charging system is not charging the battery. It should be at least 13.x, preferably 14.x.
5. Regulator Test
Disconnect the regulator. Connect your ohmmeter to the orange and tan wires. Note the reading. Reverse the connections. Note the reading. One reading should show continuity, the other should show no continuity. If the regulator does not pass this test it is no good. This is the circuit that prevents the reg from draining the batt when the bike sits overnight.
This test only tests one circuit in the regulator, so even if it passes this test it may still be no good. There are other tests of the regulator that require specialized equipment. These tests are in the factory and Clymer manuals. I recommend taking both the reg and the gen to an automotive electric repair shop for testing if needed. Note: these shops usually want to test both parts together.
6. Generator Test #1: Residual Magnetism
Disconnect both the A and F terminal wires. Connect the +ve voltmeter lead to the A and the -ve lead to ground. Run the engine at about 2000 RPM. The meter should read at least 2.0 volts. If the voltage is low polarize the generator and repeat the test. If the generator fails this test it must be disassembled for repair.
7. Generator Test #2: Maximum Output
Remove both the A and F terminal wires. Connect the +ve voltmeter lead to the A and the -ve lead to ground. Run the engine at about 2000 RPM. MOMENTARILY [not longer than 10 seconds] connect a jumper lead from ground to F and read the meter. The meter should read 25 to 30 volts DC. If the generator fails this test it must be disassembled for repair.
8. Here's a good way to bench test your generator:
1. connect a jumper from the "+" battery post to the "A" armature terminal on the gen.
2. Connect a jumper from the "-" battery post to the "F" field terminal of the gen.
3. Now take a third jumper from the "-" battery post and touch it to the case of the gen.
If all is well the generator will run like an electric motor. With the gen gear pointing away from you the rotation is clockwise.
Don't try this with the generator on the bike.
9. Polarizing the Generator
With the generator fully installed in the bike, all connections made, ignition off; connect one end of a jumper wire to the gen A, and momentarily touch the other end to the battery +ve terminal.
Usually [but not always they say], you will get a spark at the battery terminal and a light clunk sound from the gen.
10. Polarizing the Generator - The Complete Story
1. with the gen on the bench
[i] jumper the gen A to batt +ve
[ii] momentarily jumper from gen F to batt -ve
Note: This can be done the other way around,
[i] jumper gen F to the -ve batt
[ii] momentarily jumper gen A to batt +ve
2. with the gen on the bike, wires not connected
[i] jumper from gen F to a good ground
[ii] momentarily jumper from gen A to batt +ve
Note: This technique is preferred over #3 because the good ground is better than relying on grounding the F thru the reg.
Note: As with #1 this can be done the other way around.
3. with the gen on the bike, all wires connected
[i] momentarily jumper gen A to batt +ve
Note: This is technically the same as techniques #1 and #2 as the F is grounded thru the reg.
4. For bikes with a mechanical reg [1959 to 1977]
Momentarily jumper between BAT and GEN on the reg.
Note: this is technically the same as all of the other techniques as BAT is connected to batt +ve and GEN is connected to gen A.
5. For bikes with a Cycle Electric Generator/Regulator
On the Cycle Electric DGV-5000 generators you have to remove the brush cover and touch a wire from the positive terminal of the battery to the positive brush lead of the generator to polarize it. You can't polarize the generator from the external terminals. (One of the terminals is the battery terminal, and the other has an internal diode.)
You have to try pretty hard to reverse the polarity on those generators and they rarely need to be polarized.
For clarification: Cycle Electric does have a voltage regulator (the CE-540) which looks very similar. It will bolt up to a standard Model 65A generator and has external leads which connect externally between the regulator and the generator.
The CE-500 bolts to a Cycle Electric DGV-5000 generator and the regulator is internally wired to the generator.
- With the CE-540 setup the generator can be polarized by running a lead from the battery + to the "A" terminal.
- With the CE-500 you need to polarize the generator at the positive brush lead.
11. Generator Brushes Assembly: Dismantle, Cleaning, Repair
1. The brushes holder and related parts can be dismantled without removing the gen from the bike. This is useful because, in my [limited] experience, if the gen light is coming on then one or both of the brushes is probably sticking. This can be easy to fix.
I am writing this from memory, not while doing it. I think i have the removal process right.
Remove gen end cap. Remove the bracket and brush cover strap. Remove the commutator end cover. There are 3 screws visible. Two just hold the brushes to the brush holder; these do not need to be removed. The third screw attaches a wire from inside the gen to the brush assembly. Remove this screw. Now the brush assembly can be removed.
Usually it is quite dirty in there so at this point i use a spray can of electrical contacts cleaner to clean up the mess.
The brushes will spring out of the brush holder. They must be each longer than 1/2 inch else replace both. Reinstall each temporarily and work them between thumb and finger to see if there is any binding.
To re-install brushes in holder use long twist ties from the kitchen. Pick out the twist ties after the holder is re-installed.
2. To remove the gen from the bike: Disconnect the wires from the A and F terminals; remove the two bolts from the gearcase side; raise the inner end toward the 11:00 o'clock position, lower the outer end toward the 5:00 o'clock position, and remove carefully.
For the rest you really need a manual. The FM is very good. It is usually not necessary to remove the gen drive gear - this requires a gear puller to remove. The rest of the gen dismantles quite easily.
Once opened up you can do more cleaning and inspection; again using the spray can electrical contacts cleaner.
The FM contains a number of tests that you can easily do once it is opened up: field coil test, shorted or open field test, grounded armature test, and open armature test.
The shorted armature test requires special equipment which a shop would have [a growler]. Doing actual repair may require special equipment such as a lathe, and perhaps experienced hands.
Old Aug 21, 2010 | 07:35 AM
mustangwagz
Wow thanks guys! Very usefull info! imma tear into it this afternoon and see what i can find. Cuz i think brushes are close to shot. at an idle the light is coming on now so i had to bump it up a little. just over 1000 to keep light off.
i'm noticing a new problem as well..at low speed, while i'm in gear, like goin down the road slow. say in town or in traffic..it likes to jerk, and cut out violently.. almost as if its spark related.. i noticed the rear cylinder plug is rather black! almost as if the rear cyl isn't gettin the proper amt of spark.. Plug wires look original to me so i'm wanderin if they're startin to decay and loose continuity. it IS a longer wire, but only by a few inches. I'll also check the points and see what they look like.. The front cylinder is colored great. i guess i could brush off plugs and switch them to see if problem stays in rear hole, or if it follows the plug. Cuz its only at the low speed i notice this. (or low rpm when loaded..) at idle it doesnt do it..just while in gear goin down road.. so that makes me wander if its points.. Grrr...always something eh?! lol
other than just stupid little nit picking stuff, bike runs great! Thanks again guys! So far yinz have helped me greatly!
Old Aug 21, 2010 | 03:41 PM
IronMick's Avatar
IronMick
The gen light coming on at or below 1000 RPM is normal. A gen does not charge the battery at idle.
When one spark plug is colored significantly different from the other, the first suspect is either an intake or an exhaust leak. It is impossible to get a good tuneup with either of these conditions present so it is a good idea to check for these. Here are some notes ...
Intake And Exhaust Leaks Tests
You cannot get a good tuneup if there are intake leaks or exhaust leaks.
1. Check for Intake Leaks
With the engine idling spray propane gas or WD-40 around the carb/intake/cylinder head joints. Propane is best because it leaves no mess, and is most easily sucked in thru leaks. WD-40 is said to work well because it has very fine spray droplets. Be careful to not allow any of either to get sucked in thru the A/C as this will invalidate the results.
Any change in engine RPM is a leak which must be fixed.
EDIT: Experience is that this procedure will identify larger intake leaks, but it may miss very small leaks that also must be fixed. And that propane is definetly the better choice.
EDIT: I never use anything but propane for this test, and i use a lot. It is no use spraying a little, and using a lot of WD40 or carb cleaner or whatever makes a huge mess. Do not light the propane, eh.
2. Check for Exhaust Leaks
Pour about 1/2 ounce of oil into each cylinder thru the spark plug holes. Run the engine at idle. You will get lots of smoke for about 5 minutes.
All smoke should come from the ends of the exhaust pipes/mufflers. Any other is a leak which must be fixed.
Old Aug 22, 2010 | 01:46 PM
mustangwagz
I did like you said mick, used propane. No intake leaks anywhere. As far as exhaust, the drag pipe is a little loose where it bolts to the head, but no leaks there. Points checked out fine. Plug wires checked out fine too for as far as resistance. So i duno where else to check. lol but it does run great other than the slow speed at idle through town or malls.
Putting drag bars N such on at the moment. all done except i need to re route my speedo cable.
Anyone know how to remove speedo cable from the speedo gear assembly at the bottom of the cable?! i noticed a roll pin, but figued i'd ask first. That the little bugger i'm aimin to pull out?
Thanks guys!
