Ironhead A place to talk about Ironheads.
cam vent
Old Dec 26, 2010 | 04:39 PM
Miket's Avatar
Miket
1st Gear
Default cam vent
why is my 71 ironhead pushing oil out the tank lid and puking oil out the cam chest vent?
Old Dec 26, 2010 | 05:21 PM
shepdog's Avatar
shepdog
has it sat for a while without being started?
Old Dec 27, 2010 | 04:04 PM
Gunterjaeger's Avatar
Gunterjaeger
Check your lines for clogs, and make sure your check valve isnt frozen
Old Dec 30, 2010 | 06:34 PM
Miket's Avatar
Miket
1st Gear
It has set a while during the build. It seemed low a few times so I added a little but it wasn't leeking and not going in primary so I couldn't figure where the oil was going
Old Dec 30, 2010 | 06:45 PM
Miket's Avatar
Miket
1st Gear
How do I post and see replys on this. I have to google my own question to see replys
Old Dec 30, 2010 | 07:19 PM
IronMick's Avatar
IronMick
Look for either one of these, the Quote at the end on the right of each post, the NewReply on the left after the last post ...
Old Dec 30, 2010 | 07:23 PM
IronMick's Avatar
IronMick
This oil flow is referred to as Wet Sumping. Virtually all old Harleys do it. The oil leaks past the check ball in the oil pump. Flows out the crankcase vent on the cam cover when you start it up. Best to put a catch can there if you suspect this has occurred. Big error to top it up. Always check the oil level after the engine has been running for a few minutes.
Old Dec 31, 2010 | 08:59 AM
scottfisher's Avatar
scottfisher
Scroll down below 'Threads in the Forum' to 'Display Settings' and change the display from 'the last day' to 'the past week' or '10 days' depending on the frequency that you log in.
SoZo
Milwaukee Eight (M8)
Dec 2, 2017 02:21 PM
NYCFXDC13
Jun 1, 2013 03:38 PM
Miket
Oil Archive (no new posts)
Dec 28, 2010 05:36 PM
jacknthebox
May 21, 2010 08:57 AM
sadavis73
Exhaust System Topics
Jul 7, 2008 07:36 AM
