Ironhead A place to talk about Ironheads.
Battery question
Old Mar 11, 2011 | 09:03 PM
IronMick's Avatar
IronMick
Originally Posted by EvilWayz
I was told that if ba6tery termianls corrode extensively like mine do, a battery tender will show a full charge when its not, and will eventually go bad? Is this true. and if so how can I test my battery tender. ...
I have not heard of this before now, but i suppose it could be true.
The only practical way to test an automatic battery charger is to attach it to a known good battery and see if it fully charges the battery. In addition you could put a voltmeter on the known good battery while it is charging and monitor the changes. Try it on your car or truck battery.
The microcontroller inside the battery tender expects a battery to be attached - it will not function if you attach anything else like a voltmeter or an ammeter.
Old Mar 11, 2011 | 09:25 PM
Blackcherry Low's Avatar
Blackcherry Low
I assume a multimeter has both an ammeter and a voltimeter since you and mick seem to be at odds as to which I should use?
Well I would say that if you checked the output of your tender with a voltmeter, and it is putting out between 12 & 13 volts you could assume that it is working. Regardless of what amperage it is, it has to put out 12 volts or better or it won't charge your battery, plain and simple.
Old Mar 11, 2011 | 09:27 PM
Blackcherry Low
Just disconnected mine from the battery and voltmeter reading is 12.75 volts, must be a different type, but I think it's working.
Old Mar 12, 2011 | 07:47 AM
IronMick's Avatar
IronMick
Mine is a battery tender, same as the OP. I tried the same procedure and nothing on either the voltmeter or the ammeter.
Old Mar 12, 2011 | 08:12 AM
Blackcherry Low
I looked at mine today and it is one of those fancy Harbour Freight, Battery Float Chargers. Obviously doesn't have the same circuitry as the ones you guys have, I've had it for many years.
So it won't fire up even if you run the ammeter in line with one of the output leads and connect to battery?
I guess you could record battery open circuit voltage and then put the tender on it, then take another readng right away. Should be able to note an increase within a few minutes I would think with a digital meter anyway.
Old Mar 12, 2011 | 08:14 AM
scottfisher's Avatar
scottfisher
This thread got me wondering about mine, so, I had to try too....I get a split second of voltage and then nothing. The LEDs indicate it is assessing the battery while I am doing this.
Old Mar 12, 2011 | 08:35 AM
Blackcherry Low
I just checked the current flow on mine and it's been running on the battery all winter long. Disconnected from the battery, the charge voltage is at 12.77 and the battery on it's own is the same. Put the ammeter in line and it pulls 380 milliamps in the battery's current state.
They only cost 12 bucks from harbour freight and it's been working for many years. Not to mention that you can check it's operation quite easily. Might be worth the peace of mind know that it's working as opposed to the more expensive/sophisticated ones.
Old Mar 12, 2011 | 08:39 AM
Blackcherry Low
Did you have your ammeter set up for milliamps? Also with all the meters I've owned, you don't typically have to move the leads to read milliamps. My meter didn't pick up anything until I switched it to mA.
Old Mar 12, 2011 | 08:59 AM
Blackcherry Low
I'll put my tender on the XLCH when I'm out in the shop today and take the same readings and see what we get. I'm sure that battery can use a top off.
Old Mar 12, 2011 | 11:26 AM
EvilWayz's Avatar
EvilWayz
My tender works the same as micks, I can touch the leads together and it won't spark or blow the fuse. It apparently " knows" when there is a battery involved.
