Ironhead A place to talk about Ironheads.
Battery question
Old Mar 12, 2011 | 11:57 AM
EvilWayz's Avatar
EvilWayz
Alright attaching the tender to the car's battery shows a red light ( charging) so I'm off to find a fastener store and stainless steel screws.
Old Mar 12, 2011 | 03:44 PM
Blackcherry Low's Avatar
Blackcherry Low
Originally Posted by EvilWayz
My tender works the same as micks, I can touch the leads together and it won't spark or blow the fuse. It apparently " knows" when there is a battery involved.
If you want to know if it's working, just read the battery voltage before you connect the tender. Then after you've had the tender on for a couple minutes check the battery voltage with the tender still connected, and you'll see a higher voltage if it is actually working.
Just hooked my tender to my XLCH and before I began charging, the battery volts were 11.99 and after turning on tender for a couple minutes the battery volts were 12.25.
Then I hooked my ammeter in line and watched for about a minute as the current flow decreased from 600 milliamps to 510 and so on down.
ringer1969
2014-2024 Touring Models
11
Nov 12, 2015 01:01 PM
HighonHarley
Aug 21, 2015 02:29 PM
c50plus
Apr 16, 2015 11:47 PM
Hs Fatbob
Apr 2, 2013 09:25 PM
mrbuck
May 6, 2008 06:05 PM
