Ironhead A place to talk about Ironheads.
Frame identification & help
Old Apr 7, 2011 | 09:51 PM
Yosemite's Avatar
Yosemite
Default Frame identification & help
For all intents and purposes, I have what I believe to be a 1975 XLH frame with numbers matching VIN on the frame and engine. However, the following number shows up on the casting on the lower left rear; "47652-67". See attached picture.
Is this just a casting they made way back when and welded into all the frames over the years, or is this the actual part number for the frame? My HD parts catalog shows the correct part number to be 47014-73.
Additionally, the top of my seat mount bracket has been sawed off. I need to refabricate it. If someone has a 75' or so frame with the type of bracket shown in the second picture, I sure would appreciate center to center hole dimensions from the top to the bottom hole, top hole diameter, and spacing between the two vertical tabs that the seat pin goes in on top.
Thanks.
Attached Thumbnails Frame identification & help-img00015-20110408-0039.jpg   Frame identification & help-1975-frame-1.jpg
Old Apr 7, 2011 | 11:58 PM
sepixlh's Avatar
sepixlh
Frame looks 73-78 frame... you are correct that that is cast # of that part of frame.
Here is measures
Old Apr 8, 2011 | 06:33 AM
IronMick's Avatar
IronMick
Originally Posted by Yosemite
... Is this just a casting they made way back when and welded into all the frames over the years, or is this the actual part number for the frame? My HD parts catalog shows the correct part number to be 47014-73 ...
Yes, just a casting number. It is unfortunate that these often resemble part numbers.
Old Apr 8, 2011 | 08:54 AM
Yosemite's Avatar
Yosemite
Thanks guys. Knew the walking, talking encyclopedias of Ironheads would have an answer post haste.
Sepixlh, I have the same drawing/book. Unfortunately, the ONE thing it doesn't show is the height of the seat bracket or the distance between the top tabs. From my cut off version, plus pics of others, I can see that it "wraps" around the top frame rail so I can't just guess at how wide to make it when I refab it. Gotta get someone who can give me actual measurements.
here's what I have presently.
OH, another question. I most defintitely have an XLCH. However, someone has done the electric start (XLH) conversion. I have to buy a whole new wiring harness for the bike. I presume I should get the XLH harness due to the electric start, instead of the XLCH. Correct?
Thanks.
Attached Thumbnails Frame identification & help-img00010-20110408-0037.jpg   Frame identification & help-img00013-20110408-0038.jpg
Old Apr 8, 2011 | 09:32 AM
Calwoodbutcher's Avatar
Calwoodbutcher
The type of wiring harness would depend on your controls. Gotta starter button on your right HB controls? If you do run a XLH harness.
Old Apr 11, 2011 | 11:29 PM
sepixlh's Avatar
sepixlh
Model can be checked from VIN# if it starts with 4A it's XLCH if it starts with 3A it's XLH.
There is more differences than just wiring, oiltank, batterytray, clutchhub, starter, solenoid, relay...
Old Sep 2, 2011 | 10:52 AM
kaltern67's Avatar
kaltern67
Stage I
Thanks.
Hi, i'm Alfred from Italy and i'm restoring a 74 xlh and have the same problem. did you get the measurements from center to center hole?
this is my bike
maybe you or someone can help me.
Thanks
Alfred
Old Mar 14, 2022 | 03:59 AM
Floppy88's Avatar
Floppy88
Stage I
Default Help with any info on frame thank you
What's up to all im new here and hoping I can get someone that might be able to give me some info on this frame I picked up I paid $50 for it. It's rough and beat up but it's mine and before I jump into doing anything to it was hoping to find out at least an idea of what I got anything will be appreciated thank you
This is it there is no numbers that i can find anywhere. Hope the pics help thank you in advanced
Old Mar 14, 2022 | 11:05 AM
Joe12RK's Avatar
Joe12RK
Don't know what it is, but if I were using it, I'd weld a tube between the top tube near the motor mount and the two down tubes for strength.
Old Mar 28, 2022 | 09:13 PM
The412Devil's Avatar
The412Devil
Stage I
[QUOTE=Floppy88;20500425]What's up to all im new here and hoping I can get someone that might be able to give me some info on this frame I picked up I paid $50 for it. It's rough and beat up but it's mine and before I jump into doing anything to it was hoping to find out at least an idea of what I got anything will be appreciated thank you
Looks like some kind of cheap aftermarket frame. The backbone mount looks like a ironhead but the bottom tubes look too wide so idk.
Soakinwet
Jul 20, 2024 07:52 PM
Cal516
Flathead
Jul 30, 2021 04:45 PM
dmax2010
Feb 25, 2018 04:59 AM
rogue76
Shovelhead
11
Mar 3, 2011 07:10 PM
HooDoo Man
Jul 16, 2010 12:30 PM
