Clutch problem
1970 should be dry clutch. Whether to keep it that way is controversial. As a dry clutch its performance will be much better than any wet clutch setup for the bike. But you must dismantle/clean/inspect it each year to ensure that it stays dry. A wet clutch setup will require less maintenance but will have a harder pull on the lever.
You can convert to a wet by simply buying and installing new plates. Best are the Barnet wet-dry plates.
That is the extent of my knowledge, gained not from experience, but from reading these forums over the past few years. Best to get some more experienced opinions.
a stock bike, untouched, still in good condition will very likely still have a dry clutch still in it.
keep it dry if this is the case.
An example of the dry friction plates:
http://www.ebay.ca/itm/HARLEY-DAVIDS...-/200371555123
If it has been converted the frictions may look like:
http://xlforum.net/vbportal/forums/s...06&postcount=1
or
the current:
http://www.ebay.ca/itm/54-70-SPORTST...item564a4bc1b5
(best pic I could find--extra plate not neccessary though for standard riders)
The only way you will really find out what you have is to open it and look.
BUT -- Before you open it...try adjusting it.
http://xlforum.net/vbportal/forums/s...89&postcount=9
The Barnett replacement (should you choose this route) is found here:
http://www.barnettclutches.com/produ...1970&clutch_cc=
PN# 302-30-10010 would work just fine.
s
Last edited by scottfisher; Aug 9, 2012 at 11:31 PM. Reason: spell like a second grader
