Ironhead A place to talk about Ironheads.
Smoking Between Shifts
Old Jul 17, 2011 | 12:46 PM
sportster77's Avatar
sportster77
Default Smoking Between Shifts
I have an old 1977 XLCH Ironhead 1000cc Sportster that's been sitting up for some years now.
I've noticed it starting to smoke out the exhausts at idle and between shifts.
Is this a possible Valve Guide issue?
Old Jul 17, 2011 | 02:00 PM
scottfisher's Avatar
scottfisher
it hasn't run for years?
now you have just started it?
blue smoke? black smoke?
plugs fouled?
what have you done to it recently? why was it parked?
might be just a tuning issue...or, it may need top end work.
hard to say with the info you have provided, but, do a compression check. That is a good indicator of a problem with the top end.
Old Jul 17, 2011 | 08:58 PM
IronMick's Avatar
IronMick
Cylinder Compression And Leakage Tests
A compression test should be done as part of each tuneup. Record the results and follow any changes over time.
A cylinder leakage test should be done any time you are considering taking down the top end. This test gives you useful information regarding what you should look for when you have it apart.
Each of these requires a tester which you can buy at an auto parts store. A compression tester could be found for about $40.00 more or less, and a clyinder leakage tester for somewhat more than that amount. With the cylinder leakage tester you will also need a small air compressor. Should be able to find a small sausage style for under $100.00.
Use these tools once and they have paid for themselves, compared to paying $50.00 to $100.00 per hour at a shop. Buy a slightly larger air compressor [look for about 5 CFM @ 90 PSI] and you will be able to use it with air tools.
Compression Test
1. Ride the bike to get the engine to get it up to operating temperature
2. Disconnect and remove both spark plugs; insert them into the leads and place them on the cylinder heads for grounding
3. Screw the compression tester into the spark plug hole for either of the cylinders
4. Hold the throttle open, and ensure the choke plate is also open [choke **** pushed in]
5. Crank the engine through several rotations until there is no further increase in reading at the tester gauge
6. Record the final reading
7. Repeat for the other cylinder
The difference between the two readings should not be more than 10 psi. A low reading on one cylinder indicates possible valve or ring damage to that cylinder. To determine which, pour about 1/2 oz of oil into that cylinder through the spark plug hole and repeat the test. If the reading returns to normal then valves are good, rings may be defective. If compression does not return to normal then valves may require service.
Cylinder Leakage Test
This test will tell you what to look for at the top end tear down: worn exhaust valves, worn intake valves, leaky head gaskets, or worn rings.
This test is usually done immediately following a compression test. So the engine is at or close to normal operating temperature, and the spark plugs have been removed.
1. Remove the pushrods to ensure that the valves are closed.
2. Set the cylinder to be tested at or near top dead center [TDC] as this is the wear area for the rings ...
a] rear wheel off the ground, shift to 2nd gear, rotate wheel until it clicks, repeat until you get to 4th gear. Now by rotating the rear wheel you are rotating the engine. Almost impossible with the plugs in; very difficult in lower gears. For the following it helps to have either a shop assistant or a wide "wingspan".
b] you can see in thru the spark plug hole, especially with a flash light. You can also try inserting something soft like a pencil and watch it rise and fall as you rotate the engine with the back wheel; but be careful it does not break or get stuck! You will have to hang on to the pencil with left hand while rotating the rear wheel with the right.
3. Turn on the compressor, connect the gauge to the air pressure, and adjust the gauge
4. Thread the adapter into the spark plug hole and attach to the gauge
5. The gauge now shows the amount of leakage
6. Listen at each exhaust pipe. Excessive hissing here indicates the respective exhaust valve is not sealing
7. Listen at the A/C intake. Excessive hissing here indicates intake valve[s] not sealing
8. Listen at the timing plug hole. Excessive hissing here indicates the rings are not sealing
9. Listen around the cylinder/head connection. Excessive hissing here indicates the respective head gasket is not sealing
Notes
A mechanics stethoscope [with the probe removed for this test] makes a good listening device, as does a length of oil line hose.
Greater leakage results in a sound of lower pitch.
There will always be some leakage, especially past the rings.
Old Jul 19, 2011 | 09:34 PM
sportster77
Thanks for all the information.
Old Jul 19, 2011 | 10:46 PM
IronMick's Avatar
IronMick
Originally Posted by sportster77
... smoke out the exhausts at idle and between shifts ...
I am wondering now if smoke on acceleration is a symptom of a different problem than smoke on decel, such as between shifts. Anyone?
Old Jul 20, 2011 | 07:27 AM
sportster77
There is a puff of smoke at initial acceleration and this is coming from BOTH cylinders.
I've ridden behind on another bike to look at her exhaust pipes.
I haven't had the chance yet to do the compression and cylinder tests.
Old Jul 20, 2011 | 08:22 AM
Chunk's Avatar
Chunk
I always associate smoking exhaust w/ excessive oil in chamber either accelerating or decelerating, like saying, but simple accelerating could be a weak plug/ wires.
Old Jul 20, 2011 | 08:25 AM
IronMick's Avatar
IronMick
Whatever the compression and leakage tests show, my expectation is that this is a sign of normal engine wear and that it is not a serious problem - certainly not serious enough to rebuild the top end during riding season.
Old Jul 20, 2011 | 11:55 AM
sportster77
I'll post the results in a couple weeks, got to go out of town.
Old Aug 7, 2011 | 09:27 AM
98Ultra's Avatar
98Ultra
Mine smokes between shifts also. Some at start up. Strange thing is, some times it smokes, some times it doesn't. One day I'll fix it, in the mean time, I'll ride it.
cliffside tattoos
Ironhead
Sep 21, 2012 09:30 PM
73 ironhead guy
Ironhead
Sep 19, 2012 07:35 AM
85Sporty
Ironhead
Jul 29, 2012 07:13 PM
ridefree1
Ironhead
Mar 18, 2011 07:34 PM
Sportydkt
Ironhead
Jul 25, 2010 06:19 PM
