Waking from a 30 year slumber
Installing a different carb is not just a simple bolt-on operation. It will stick out further and bump your knee if you have forward controls, and you cannot use the original air cleaner or the original carb support bracket. And you have to work out which jets etc will be best for your setup. It is a lot of hassle that i have not wanted to be bothered with.
The two most popular choices that i have seen are a used CV and the Mikuni VM38 ...
The CVs give the very best price : performance ratio. They are plenty and cheap on eBay, typically ~$75, certainly less than $100. And once tuned up they give excellent performance and gas mileage.
The VM38 needs no tuning runs - install following the factory directions and you are good to go; a bonus for kick start bikes as these are said to be one-kick carbs.
One of those would be my choice.
With the S&S carbs keep in mind that there are a few models, designated by a letter - B, E, G, shorty, whatever. These are not all appropriate for an IronHead. Be sure to research before deciding, and be sure to decide on a scientific basis, not just on what the believers say.
Here are some opinions ...
Best Carb for an IronHead
If you are from NJ and haven't been to Nicks, it's awesome! The 2nd floor is a museum with Harleys dating back to at least 1908. Lots of cool panheads, knuckleheads, a few K models and some military models with sidecars.
I took the carb off today (stock keihin) and the needle will move up and down with the float. Mind you I replaced the original needle with a new one from an HD rebuild kit, and when I did that the tang on the float needed a lot of bending to get back to the right spec.
Another thing I noticed when taking the carb off/apart today that wasn't there last week when I rebuilt it. There is a yellow spot that has formed on the float itself. When I rub it the yellowish stuff will come off like fine dust.
