Ironhead A place to talk about Ironheads.
lowering front end
Old Sep 9, 2013 | 09:02 AM
cc rider47's Avatar
cc rider47
2nd Gear
Question lowering front end
im looking for the best way to lower the front end a bit on my 73 ih. any ideas? thanks
Old Sep 9, 2013 | 02:09 PM
iwombat's Avatar
iwombat
Get a set of shorter fork tubes. If you want it really short, you'll probably need to clip your springs.
Old Sep 9, 2013 | 06:50 PM
IronMick's Avatar
IronMick
I have no direct experience with this myself, but i believe the shorter fork tubes is the only option. You cannot raise the tubes in the trees as you can on some bikes because the tubes are tapered at the top. I think it is not practical to cut off either the top or the bottom because of fitment.
Best source for info and parts ...
Forking by Frank
Frank's Maintenance and Engineering, Inc.
http://www.frankmain.qpg.com/
Old Sep 9, 2013 | 07:43 PM
johnjzjz's Avatar
johnjzjz
when we had in the past extended a front fork - you add a tin or plastic tube that is the same length that you extended the fork over the stock length
in the end it makes apples apples for right shock type ride cushion and travel --
so you need to buy shorter forks BUT i do not believe they are a stock item at franks anymore as no one really does that - the first high man hole cover should be the end if that idea -- jz
Old Sep 10, 2013 | 12:13 PM
iwombat's Avatar
iwombat
I run a 2" shorter tube on my '73 forks. I clipped the stock length spring down 1" (but I'm running thicker springs than stock). It rides a little stiff, but not a lot. It's a better match for the profile of the 16" rear I swapped in for the 18". Make sure you find tubes for the '73/'74 front end. They may be getting hard to find since the Kayaba fork was fairly short-lived.
travalab
Apr 24, 2019 11:22 AM
ffatboy03
Nov 5, 2013 01:05 PM
Berty
Nov 9, 2012 10:01 AM
SpicOfTheDevil
Mar 8, 2011 08:33 PM
hogwyld79
Jan 9, 2007 07:44 PM
