clutch
Old Oct 6, 2016 | 10:30 AM
imchuckm's Avatar
imchuckm
Originally Posted by mchanu
The clutch engagement process isn't necessarily the problem. The problem is where it engages. Way too far from the grip. Made it very uncomfortable to do slow riding drills. Don't know why HD has to do that. They could just as easily have made it engage a more reasonable distance from the grip. Everyone doesn't have gorilla hands. Since there are no adjustable levers for these models yet I ended up bending my lever to make the engagement point much closer. Much improved for me now.
Would you mind letting us know in detail how you bent it? I've thought about doing the same thing, but all I could think about was a broken clutch lever.
Old Oct 8, 2016 | 12:43 PM
mchanu's Avatar
mchanu
Sure. I've bent two of them. One I heated first. And this one I bent cold in a hydraulic press. Took about 3 tries to get it right. But it worked fine. Figured I hated the stock lever so I had nothing to lose. If it broke I'd just buy another.
Old Oct 8, 2016 | 01:02 PM
Larry Anderson's Avatar
Larry Anderson
Stage III
Hi i have 2015 Flhtk the is driver nut chatter like sew machines dose engage all out no adjusted meant very unhappy i think had all i take 27 k
Old Oct 8, 2016 | 01:19 PM
imchuckm's Avatar
imchuckm
Thank you! Your comment about "hating the stock lever" makes perfect sense.
Old Oct 8, 2016 | 01:22 PM
JesseDyna's Avatar
JesseDyna
As I understand it, motor cops are accustomed to having a pretty wide range of friction for a clutch for their various maneuvers. I wonder how LEOs would adapt if they are going to use the new model. Anyone confirm/deny?
Old Oct 9, 2016 | 12:13 AM
stro1965's Avatar
stro1965
Are you saying the '17 clutch is different than the hydraulic clutch used on '14 and up Rushmore bikes?
Old Oct 9, 2016 | 07:29 AM
mchanu's Avatar
mchanu
Yes. That is true. Different clutch and different master cylinder.
Old Oct 9, 2016 | 08:59 AM
RSDUDA's Avatar
RSDUDA
yes very different
Old Oct 9, 2016 | 03:55 PM
PDX_Zoom's Avatar
PDX_Zoom
I found the clutch engaged too far out for my fingers as well. The dealer said they could adjust them slightly, and that if that isn't enough, we can go to adjustable levers. I haven't picked up the bike yet to see if the adjustment worked well enough yet.
Old Oct 18, 2016 | 07:58 AM
RSDUDA's Avatar
RSDUDA
ok so after putting some miles on this past weekend and really studying the clutch friction point it seemed to get worst after the bike was warm to the point of scaring me a few times trying to pull out into traffic so called the dealer and dropped it off Monday they called me Monday night and said that after bleeding the system it felt good till they road it and after it got hot went to hell again so Harley want's them to measure it cold and then measure it hot and call them back
