Oil Temps
Did a poker run Saturday with runs fifty miles between stops. The temps were running 223 degrees riding two up. At 90 degree ambient temp.
On Sunday the longest non stop run was a hundred miles in 90 degree ambient temp. The oil temp was 233 when I got home. I was riding down the hwy at 75 to 80 mph.
I don't have any long runs coming up in the near future. So this report is pretty limited. I'm still a little surprised at the temps. The oil is cooler than an old soft tail I used to run years ago. There's not much chance on traffic jams where I live. (thank god I got out of all that mess) I need a vacation, so I can see whats really going on.
This is on a oil cooled FLRTXS.
And of course that is making people go crazy since everyone is an internet engineer...
Thank you for your observation. So 90 degrees ambient and seeing 233... That's more in line with others are seeing here locally.
I have yet to stick a thermometer into my Twin-Cooled to see what's what but will sometime this week.
On my twin-cooled 17:
This afternoon at 88 degrees, sump temp was 230 on the HWY 70-80 MPH, 245 in stop and go traffic right after. That's 7 miles of stop and go and it only reached 245. Pretty nice.
Conditions:
Ambient temperature during testing upper 70's
In Town riding with little traffic but normal stop lights
Speed limited to posted speed limits (35 - 45 mph)
Results:
Measured Peak Engine temperature = 340 F
Measured Peak Oil Sump temperature = 267 F
Measured Peak Head Oil Return temperature = 290 F
So for me, its change the oil to full synthetic and wait for the fan assisted oil cooler to come off back order. Once the new oil cooler arrives I will install and test again.
Oil breaks down duh. You can change the oil when it gets dirty, another duh. The whole point of oil is to lubricate the engine and prevent it from not destroying itself.
Do you want to run cooler temps for longer service intervals? You still have to change the oil anyways every 5K, so why does it even matter? Oil is suppose to break down, do you not want it to breakdown?
Luckily my bike consumes oil down to the last 3 ticks of the oil dipstick when it is time to change the oil.
Jut to add a few things i have noticed on the air cooled v-twins i have owned & ridden over that past 46+ yrs riding on the street & wrenching bike/car motors is when oil temp hits approx 220-230deg f things that to change like more valve/lifter noise along with considerably lower oil pressure.
My TC 96" mostly stock used to run approx oil temp in 90+ deg f summer heat of 6-8psi @ idle & 32psi @ cruise resulting in increased valve & lifter noise,detonation at times along with much more negative performance & rider comfort issues too.
But post installing an ultracool oil cooler with twin cooling fans & wards cooling fans oil temp was reduced 50deg f hot oil pressure in summer heat improved from 6-8psi @ idle & 32psi @ cruise WITHOUT COOLING to now 18psi @ idle & 45-47psi @ cruise in same summer heat along with valve train being totally quiet and no more detonation too.
Oil temp prior to installing the 2 cooling mods used to run approx 230 @ cruise,250+ deg f in moderate traffic and approx 270-280 deg f in heavier traffic in summer heat.
Post installing the 2 cooling mods oil temp in my bike nor run approx 185-190deg f @ cruise ,215-220deg f in moderat traffic & 225-230deg f max in heavy traffic in 90deg summer heat.
Now with the 2 cooling mods & spectro oil in more extreme 98-100+ deg f summer heat oil temp @ cruise still runs 190ish deg range but after enough miles & time will slowly increase to 215-220deg f where the twin elec cooling fans kick on.
Then with cooling fans on the oil temp will either returns to 190-195ish deg f where they turn off again or in worst case the cooling fans remain on for a longer period of time keeping oil temp from going over 225-230deg max @ cruise in 100+ deg heat and eventually reduce oil temp 190-195deg f after being on for a long time vs without cooling oil temp hitting 250+ deg f @ cruise in same cond.
And in moderate avg everyday traffic hitting 3-4 stoplights in a row then up to 45-50mph for a couple miles then back 2 stoplights again in 98-100+ deg f summer heat with the 2 cooling mods maxes out @ approx 230-240deg f even sitting still in traffic vs oil temp hitting 275-280deg f without the 2 cooling mods in avg traffic cond and pushing 290-300ish deg f in heavy traffic.
And again,thats also with running spectro 20w-50 motorcycle oil specifically formulated for lrg disp HD v-twins that i found from testing in my bike faired better then HD syn3 syn and a few other popular 20-50 motorcycle oils were in my bike when it came to reducing valve train noise & maintaining better/higher oil pressure in summer heat.
Scott
