aim clutch
Old Jan 5, 2017 | 01:58 PM
  #31
Gamma742's Avatar
Gamma742
Originally Posted by Steve Cole
As far as I have been able to find out, All of the A&S factory clutch assemblies are the same other than the springs. So it has to be something else causing them to be all over the road, as they should all be very much the same. Now we know they have been changing the hydraulics so that's the area I'm trying to follow along now. I've ordered a new master for the 17 RK so I can take it apart and measure the bore and stroke on it and I have an earlier one already so I will compare the two of them, once the new one gets here.
I would think the the Master would remain unchanged as the big change in 2017 in the Engine, Tranny, Cases and such. I would look into the Slave Cylinder, it may have been retooled. No reason to change the master as it sits atop the handlebars same as the Rushmore bikes.
Old Jan 5, 2017 | 02:29 PM
  #32
ron1026's Avatar
ron1026
There must be a difference in the masters as the 2017 lever is different than the earlier ones
Old Jan 5, 2017 | 02:33 PM
  #33
Steve Cole's Avatar
Steve Cole
HD EFI Guru
It has been changed, that why I ordered one to play with.
Old Jan 5, 2017 | 06:23 PM
  #34
ron1026's Avatar
ron1026
Update, got the clutch today. Differences, the new springs ( orange ) are noticebly shorter than the stock, the new springs are about 20lbs lighter in pressure for each, that means total of 60lbs less overall, and that is noticeable when pulling the lever. Took quick trip around block ( weather bad ) and it feels much nicer now, wasn't able to get on it but I'm thinking it's going to be fine, but time will tell.
Old Jan 5, 2017 | 07:27 PM
  #35
GlidingJoe's Avatar
GlidingJoe
I agree the master is changed.... the master reservoir cover is not interchangeable with 16 to 17 model year. 17 is differant
Old Jan 6, 2017 | 07:58 AM
  #36
FLSTFI Dave's Avatar
FLSTFI Dave
Interesting. I would agree it has to be in the Hydraulics. The clutch in my 13 CVO King and 15 CVO Road Glide felt very close and release was similar, about the same size friction zone. That change when I did the AIM upgrade on the King with the springs for 15t torque.
The 17 is clearly different. With springs being the only change, hydraulics has to be the difference.
Old Jan 6, 2017 | 09:22 AM
  #37
George Bryce's Avatar
George Bryce
From MoCo on new clutch master, FYI
What improvements did you make to the driveline?
For starters, we retuned the primary. The compensator bearings were changed, and the ramps changed. This is another place where we analyzed the crap out of it. We completely correlated our models with many vehicles. The goal was smooth torque in all conditions. Complementing that, the clutch was changed to an Assist and Slip Clutch. As you apply load, it pulls the clutch together to minimize spring pressure. Less lever effort per foot-pound that way. Whenever you up performance, you need more spring in the clutch. We went with a hydraulic Brembo activation system across the board on the Touring models to offset that. It’s better at the lever ergonomically.
Old Jan 6, 2017 | 11:53 AM
  #38
GlidingJoe's Avatar
GlidingJoe
There you have it!!! Thanks George.
Old Jan 6, 2017 | 01:19 PM
  #39
ron1026's Avatar
ron1026
If the moco thinks its better at the lever, who are we to disagree LOL. I am happy now.
Old Jan 6, 2017 | 08:04 PM
  #40
Gamma742's Avatar
Gamma742
Yeah right.. although I disagree. Thank goodness for AIM and the orange springs
