pressure and heat not the same on both mufflers
Old Jan 23, 2017 | 09:09 AM
snowdevil23's Avatar
snowdevil23
Default pressure and heat not the same on both mufflers
started the road glide up on Saturday, just to hear the cfr's roar. after about 10 minutes noticed some moisture on the inside of the right side muffler outlit . reved the motor a bit and blew the little droplets out. then noticed that the left side started to get some building up in it. reved the motor a bit and the only about half of the droplets blew out. put my hand up to that muffler and notice that the exhaust coming out of that muffler was cold and only about half the pressure. now I know that there is the crossover pipe going to that side , but not any heat from the exhaust . has anyone else noticed this and if that's the case is most of the exhaust going out of the other muffler ?
Old Jan 23, 2017 | 09:17 AM
mjwebb's Avatar
mjwebb
sounds like working as designed..think it's somewhere around 70/30 split, maybe even more, but sure others will 'pipe' in..pun intended
Old Jan 23, 2017 | 09:56 AM
sixguns's Avatar
sixguns
Yes, like mjwebb said its normal. without getting technical, most the exhaust flow and heat goes out the right side pipe, because the exhaust takes the least path of resistance. So you will notice different soot,condensation, etc,etc from side to side.
Old Jan 23, 2017 | 03:01 PM
dpmerrill's Avatar
dpmerrill
I don't know, but I'd imagine the ratio gets a little more balanced at the higher rpms.
Old Jan 23, 2017 | 04:48 PM
SWThomas's Avatar
SWThomas
Have you taken a look at the pipe that goes under the bike to the left side???? It looks like it has been smashed almost flat. The M8 exhaust is a 2 into 1 with a cosmetic extra pipe. That left pipe is worthless other than looks.
Old Jan 23, 2017 | 05:29 PM
Gadgetech's Avatar
Gadgetech
And for looks it turns the end cap more black than the right side.
Old Jan 23, 2017 | 08:10 PM
YPD485's Avatar
YPD485
I also noticed that the left muffler outlet is blacker than the right. On the TC's, it was the opposite. Go figure.
Old Jan 24, 2017 | 05:11 AM
smitty901's Avatar
smitty901
Called scavenging. Amazing design HD cam up with long ago. Helps keep torque up with out robbing HP. Balance working just as it is intend.
Old Jan 27, 2017 | 07:43 AM
Drodrigueznyc's Avatar
Drodrigueznyc
so technically the cost of aftermarket slipons should be reduced to half!
Old Jan 27, 2017 | 08:52 AM
rockabillygrl's Avatar
rockabillygrl
I noticed this same issue after I installed my new slipons. It was very cold that day and so I had condensation coming out of the left pipe too. After it got warmed up to operating temp it seemed to balance out. I thought something was wrong.
