I do believe my my trans broke
Old Mar 13, 2017 | 06:57 PM
Ultra61's Avatar
Ultra61
Default I do believe my my trans broke
Big Snow storm coming so I was relocating the bike on the property, but before this I'll run it around the block.. as I was hastily doing so it appears 4th gear went away.. it wined then in 1st to third but engaged enough to get me home.. in neutral its wining as well w clutch out.
Old Mar 13, 2017 | 07:14 PM
BrokenAnchor's Avatar
BrokenAnchor
Didn't you get a stage kit upgrade? As long as everything was done at HD you will be covered under warranty. I would definitely give them a call and have them pick it up and have a look at it. Doesn't sound good at all. Best of luck.
Old Mar 13, 2017 | 07:16 PM
Iceman24's Avatar
Iceman24
2017...warranty fix - you're good!
Old Mar 13, 2017 | 07:25 PM
Ultra61's Avatar
Ultra61
Yeah I'm sad but ok.. my concerns is how long till fixed and why am I braking the trans on a quick shift?
Old Mar 13, 2017 | 07:28 PM
Ultra61's Avatar
Ultra61
Yeah they did the work.. no good at all
Old Mar 13, 2017 | 07:32 PM
BrokenAnchor
Well at least you are covered and better this time of year then later on in the year when the weather is better. Good luck and keep us posted.
Old Mar 13, 2017 | 07:33 PM
checkers's Avatar
checkers
If the bike"s been setting for weeks and cold wether, the clutch discs can be dry and behave this way. They have been now soaked for a time, may try it again and it may be fine.
Old Mar 18, 2017 | 08:44 PM
Ultra61's Avatar
Ultra61
Default 3rd gear
3rd gear a little smoother
Shambles of teeth
Old Mar 18, 2017 | 08:46 PM
Yamaharley's Avatar
Yamaharley
Dude!! What the ****? Was the gear not properly hardened for the application? That's insane.
Old Mar 18, 2017 | 08:48 PM
Ultra61's Avatar
Ultra61
That's what there saying at the shop
