Clutch Safety Switch Problems
Old Oct 11, 2017 | 11:39 AM
  #41
JShep70's Avatar
JShep70
Mine has been doing it for awhile on and off. I normally start in neutral so I keep forgetting. I'll try to lube the switch as well.
Whatever you don't try to lube the twist grip sensor. I tried that and had to replace it on my dime.
Old Oct 11, 2017 | 11:50 AM
  #42
Quik's Avatar
Quik
My question is, if the bike won't start in neutral and I just leave it as is, will it cause any further damage or issues other than having to start in neutral?
Old Oct 11, 2017 | 12:13 PM
  #43
FredCa's Avatar
FredCa
Nope it won't hurt a thing. It is more of a convenience issue and possibly a safety issue. If you stall your bike in traffic, it could be the difference in being able to start the bike quickly and ride away from danger.
Old Oct 12, 2017 | 07:49 PM
  #44
Quik's Avatar
Quik
Had mine replaced today, p/n 71500128A, the whole left hand switch pack has to be replaced.
Old Oct 13, 2017 | 06:44 AM
  #45
jpooch00's Avatar
jpooch00
I think that that switch also turns on the brake lights. If it's not working, then no brake lights.
May be wrong, but I think that;s how it works.
Old Oct 13, 2017 | 09:35 AM
  #46
14GuineaPig's Avatar
14GuineaPig
The clutch switch is in the Left Hand Control Module while the RHCM has a similar switch for the front brake lever. AFAIK they are completely independent of each other.
Old Oct 13, 2017 | 11:34 AM
  #47
Oldskewl's Avatar
Oldskewl
Originally Posted by FredCa
I was experiencing my bike not starting in gear intermittently and it seemed to be getting worse over time. While at the dealership for another issue, I mentioned it to the service manager. He asked who did the 5K service on the bike. I told him I did it myself. He told me to make sure I lubed the neutral plunger switch with Harley Lube at every service. I had lubed the clutch lever but not the plunger switch. When I got home, I squeezed the clutch lever and gave the neutral switch a good shot of lube. That was 2 weeks ago and the bike has started in gear every time since.
I plan on lubing the switch tonight.. from the diagram on page 3 of this thread it looks like the plunger is inside the housing. Did you take apart the housing to lube it?
Also, not sure what "Harley Lube" is other than some over priced wd 40
Old Oct 14, 2017 | 06:32 AM
  #48
jpooch00's Avatar
jpooch00
Red face Oopsie!
Yeah, that post about the brake lights was a total brain-fart on my part.
What I should have said is that that switch also turns off the cruise control when the clutch lever is pulled.
Luckily for me, at my age I can just call it a "Senior Moment", instead of feeling like an idiot!
Sorry for any confusion.
JP
Old Oct 14, 2017 | 09:52 PM
  #49
FredCa's Avatar
FredCa
I was able to lube the plunger switch by squeezing the clutch lever. I don't know what type of oil the Harley lube is? Since lubing the switch my bike has started in gear every time.
Old Oct 15, 2017 | 04:14 PM
  #50
FredCa's Avatar
FredCa
Sorry this is late but maybe it will help. When you squeeze the clutch lever, you can see the plunger switch. See the attached video. We rode again today and it continues to operate properly.
File Type: mov
