M 8- Valve train noise SE Stg 3 114
Old May 17, 2017 | 06:48 PM
henryg's Avatar
henryg
Update:
I was able to be near my dealer to produce the noise and they immediately
grabbed the stethoscope and determined it was more than likely the lifters. BHD (yes in HD Forum's top 7 North American dealers) took my bike in and replaced all four lifters. Better than ever! Bike is quiet and runs like a champ.
Thanks to everyone for your replies and responses. Big shout out to Barrie Harley Davidson. With reason, my favourite dealeship!
H
Old May 17, 2017 | 08:15 PM
mjwebb's Avatar
mjwebb
Originally Posted by henryg
Update:
H
awesome! question though..did they say what the cause was, and based on that, it is permanently resolved or may recur? just curious, thanks
Old May 18, 2017 | 07:45 AM
DRBUICK's Avatar
DRBUICK
You guys know all they are is a gn ls1 lifter. Put ls7 lifters in and golden
Old May 18, 2017 | 12:01 PM
stixvrad's Avatar
stixvrad
I wonder if the M8 has a low volume of oil going to the lifters and the earlier GM units cant fully pump up or have trouble staying pumped up? That , combined with new motors using uber thin oil might mean the later LS7 lifters might have tighter tolerances and can stay pumped up with a smaller oil supply.
Old May 18, 2017 | 08:27 PM
henryg's Avatar
henryg
All good comments/questions. I was told the lifters were defective or "were not functioning properly" hey sh#t happens. I've put over 500km since, and they are super quiet. The bad ones were noisy off the hopp. If this is my last post on this topic, it means all is well.
Thanks everyone!
Ride safe & keep it twisted!
H
Old May 18, 2017 | 10:31 PM
hattitude's Avatar
hattitude
The lifters are a chevy LS lifter mine is getting LS7 lifters '
Your choice if you want to run Chevy V-8 lifters in a twin cam. Many have done it, and report no problems.... I wouldn't buy a used bike that ran chevy lifters...
The chevy spec lifters are dimensionally identical to twin cam lifters, but internally different.
This S&S video kind of overstates the difference, due to the engines only running at idle rpm (a little marketing hype no doubt). Nobody idles that long, that I ride with. I'm sure the chevy lifters will flow oil at higher rpm/pressure, but the video does demonstrate there is a significant difference in oil flow rate between the S&S twin cam lifter and a chevy lifter...
I won't skimp on lifters... but each to their own....
Old May 19, 2017 | 10:39 AM
stixvrad's Avatar
stixvrad
https://www.youtube.com/watch?v=fMoRaHJRrhc
I took DRBUICKS post ( " You guys know all they are is a gn ls1 lifter. Put ls7 lifters in and golden" ) to mean that HD used GM lifters in these things.. What your saying is, thats not the case, correct?
Old May 20, 2017 | 11:19 PM
hattitude's Avatar
hattitude
Harley absolutely does not use GM lifters, pretty much....
I am no lifter expert...... Never took one apart, measured inside tolerances, or performed flow tests... But I have always changed my OEM cams by 20K at the latest and I always replace the HD lifters in the process (unless they are the old Hylift brand). I have researched different lifters for years... and I took notes...
That "urban legend" of HD being the same as a GM lifter, was born when Harley went to a Delphi brand lifter from the Johnson Hylift lifters. The Johnson had a special 0.655" hi-volume/ hi-pressure plunger piston and valve body. This handled the temp ranges and pressure variance of an air-cooled engine like a Harley. The new Delphi was basically a small block chevy lifter... but, to serve the needs of the HD engine, Delphi tried to boost the hydraulic psi by decreasing the piston diameter. This caused a smaller high pressure oil reservoir. The smaller oil volume allows the lifter to chatter.....
So while the Delphi lifter design started as a GM small block lifter, even Delphi knew they needed to make changes to satisfy the requirements of the HD engine.
I have never read of a problem or design issue with S&S (standards or premiums), Johnson Hylift, or Woods directional lifters. I'm sure there are other quality HD spec lifters of which I have no experience/information. A GM small block lifter is NOT one of them....
I am unaware of a quality builder that recommends GM lifters in their builds...
Like I mentioned, I believe the S&S video exaggerates the difference, but a difference in oil flow between S&S & GM lifters clearly exists...
Your bike, your choice, but GM lifters won't go in my bike... nor would I buy a bike that used them...
Robtarra39
May 1, 2016 11:37 AM
cmancini26
Oct 17, 2012 06:18 PM
mang0
Sep 11, 2012 09:19 PM
Ric27
Oct 7, 2010 08:01 PM
brandanfinn
Mar 11, 2008 11:30 PM
