M8 Clutch
Old May 6, 2017 | 06:00 PM
jstablum's Avatar
jstablum
Stage IV
Default M8 Clutch
Just purchased a 2017 Road King Special. Put about 100 miles on it today and noticed a clunking noise when pulling in the clutch to shift, particularly from first to second. Anyone else notice this??
Old May 6, 2017 | 06:33 PM
Max Headflow's Avatar
Max Headflow
Yep..
Old May 6, 2017 | 07:28 PM
mjwebb's Avatar
mjwebb
if your Harley doesn't clunk, rattle or shake at all take it in immediately to get checked out!
Old May 6, 2017 | 08:20 PM
Max Headflow
And I thought you were supposed the press the start button..
Old May 7, 2017 | 05:50 AM
WildX's Avatar
WildX
It's normal for the soft clutch installed in the 2017's
Old May 7, 2017 | 06:27 PM
103Eagle's Avatar
103Eagle
OH it gets better, not the clunk, but you may even feel the clunk in the clutch lever..................for real!
Eagle Out
Old May 8, 2017 | 06:20 AM
snowdevil23's Avatar
snowdevil23
had it real bad after bars and lines were installed . just happened to check the trans for oil level, it was low. barely on the stick , and well below the add mark. . so I added about 5-6 ounces of trans. + and a lot of the so called bump is gone. check your trans, Harley saved some money there, and just go to prove that the dealers p.d.i. isn't worth a ****. but that's on me , should have checked it when I bought it in December.
Old May 8, 2017 | 08:56 PM
TwiZted Biker's Avatar
TwiZted Biker
Mine sounds like you're tossing a hammer into a bucket 1st through 3rd, 4th and up it isn't bad.
Old May 9, 2017 | 08:24 PM
jstablum's Avatar
jstablum
Stage IV
Thanks guys. Will be checking the transmission fluid tomorrow night. Will let you know what I find. Other than that, enjoying the new engine. Big upgrade to my 96 ci Street Bob, just trying to get used to the quiet of the new engine!
Old May 10, 2017 | 07:57 PM
grayjoe's Avatar
grayjoe
6th Gear
Brought my 17' King in 2 weeks ago to the dealership and still haven't heard a word on it. My problem with the clutch is that it sort of went limp after awhile. It was just like hanging there and the engagement spot was all over the place. Any ideas. Thanks.
