Oil Leak, again...
Old Sep 11, 2017 | 09:05 AM
fordhd2005's Avatar
fordhd2005
Default Oil Leak, again...
Bought my 2017 FLHTK in July. Had it a week and then had to take it back because it was leaking oil pretty bad. It was coating the right side of the bike to include the back seat and tour pak. The culprit was a defect in the rear cylinder head. It was replaced and that fixed that problem. Then I noticed it was still dripping oil into the air box. I assumed it was blow by. When I did the 1k mile service, I only refilled the oil halfway up on the dipstick (measured when hot). Still dripping oil. Before I left on a recent 1800 mile trip, I made my own breather bypass contraption. Turns out, it was not excessive blow by because the oil wasn't coming out the breather bolt but somewhere around it. I had also stuffed some paper towels in the air box to soak up the oil to keep it from dripping out. It helped, but oil still found its way out. I don't know exactly where it's coming from except it's in the general area of the front breather bolt. Oil gets into the air box and also runs down the outside of it on the engine side. I took it back in last Wednesday and am still waiting to hear what's going on and what the culprit/fix is. I really hope that's the last of the issues. I really like this bike and enjoyed the ride. I rode interstates, back roads and in the mountains. It rained a lot but it was still enjoyable. The bike performed and handled great. I'll update with the culprit and fix when I hear something, just in case anyone is curious...
Old Sep 11, 2017 | 09:34 AM
Thingfish's Avatar
Thingfish
Sorry to hear that. Glad it's running good otherwise. Hope they figure it out soon and keep us posted.
Old Sep 11, 2017 | 09:42 AM
bob2002's Avatar
bob2002
That still sounds like the old blow by issue.
Old Sep 11, 2017 | 09:48 AM
stixvrad's Avatar
stixvrad
Catch container inside the air filter housing. 6.4 oz plastic oil container and some hose.Works great. No fasteners needed, plenty of room to hold oil. It fits snugly in there. Had it on for 500 miles and no issues. Poke holes in the red cap as a vent.Make sure the hose going in is at least an inch off the flow of the bottle so oil build up doesnt block the end of the tube going in.
Old Sep 11, 2017 | 10:06 AM
bob2002's Avatar
bob2002
Why should you need to do that, what does your dealer say?
Old Sep 11, 2017 | 12:16 PM
stixvrad's Avatar
stixvrad
For me it was a very slight dribble of oil out of the hose that aims into the throttle body. I just got sick of dealing with light oil spots on my exhaust.
Old Sep 11, 2017 | 12:29 PM
fordhd2005's Avatar
fordhd2005
I had this very similar setup, just used a different container. I even zip-tied the hoses to the breather bolts to ensure a tight seal and wrapped the breather bolts with Teflon tape. But I like I said, very little oil was actually coming out the breather bolt into the tube. The oil is coming from somewhere around the bolt though, just can't pin point exactly where. Before I rigged this contraption up, I didn't notice any oil in the air filter. There was evidence of some going into the throttle body but it was minimal and probably normal. Hopefully I'll hear something later today...
Old Sep 11, 2017 | 12:41 PM
mastergunnera8's Avatar
mastergunnera8
So you left it like that when you gave it to the dealer? with all this EPA stuff goin on? This is a 17 right?
Old Sep 11, 2017 | 01:54 PM
lp's Avatar
lp
I did with my bypass/catch can. Tech even commented on how much he liked it.
Every time I see a pic of that catch can you made Stixvrad, I giggle. So genius. Well played.
Old Sep 11, 2017 | 02:03 PM
fordhd2005's Avatar
fordhd2005
Yes, it's a 17' and I left it like that so they can see exactly what I'm talking about it and not assume it was blow by or "normal" lol...
