M8 Performance Recommendations
Old Oct 8, 2017 | 04:26 PM
lhgdale's Avatar
lhgdale
Default M8 Performance Recommendations
Hello, I put some money down the other day on a 18 Bonneville Salt Pearl RGS. My plan is to do all the performance items at once probably around the 1000 mile service. I have a Power Vision Tuner so I'll just get a new license for it but everything else I'm open for suggestions.
I'm looking for low bottom end power up to around 5500 rpm. I like to hot rod and play around but I'm pretty easy on the bikes in general.
I'll be changing:
Cams - Looking at Woods 222's or Andrews
Intake - Zippers Max Flow or Harley's Screaming Eagle
Exhaust - No Idea other than I want BLACK, since the 18's come with stretched bags I'll need a good 2-1-2 system or a dummy pipe for a 2-1 system.
Thanks in advance for the help and suggestions.
Old Oct 8, 2017 | 05:32 PM
G-Reese87's Avatar
G-Reese87
I'll be changing:
Been doing some research for when my 18 comes in and for intake the screamin eagle 90 degree bend one is really nice. As far as cams check out the cycle Rama 460 I seen some dyno sheets on here and they seem to produce good numbers and a nice steady curve in power and torque. Exhaust is seriously something everyone is going to say is completely subjective. There really isn't a right or wrong answer it has to be what you like. First you have to decide what's more important sound looks or performance. For me I'm looking into the rinehart slimline duals to keep the low end torque and the svt boneshakers. Little pricey but imo best sounding mufflers so far. Once again that's to my ears maybe not yours or others. Good luck with everything.
Old Oct 8, 2017 | 05:47 PM
MPD12's Avatar
MPD12
I have also ordered a 18 RGS Bonneville Salt. Bike will be in next month. So far I’ve ordered Vance & Hines Power Duels w/ Eliminator 4” mufflers (black of course). S&S Stealth Air Cleaner w/ Air Stream cover. Power Vision Tuner.
My local bike shop has had great results with Woods 222 cam. I would love see if any other cams get better results.
Best of luck with your build.
Old Oct 8, 2017 | 07:29 PM
Steel Wheels's Avatar
Steel Wheels
Look at the 460 from Cycle Rama. Lots of good reviews. Street Cannons are near the top for torque numbers - I was going with S&S but changed my mind.
Old Oct 8, 2017 | 08:40 PM
lhgdale's Avatar
lhgdale
Thanks guys!!!! That 460 Cycle Rama is making some great power. I read a few threads that people are not pleased with the 222 cams. The 460 is my pick.. Thanks for the info.
Old Oct 8, 2017 | 08:51 PM
lrcormier's Avatar
lrcormier
Since your already planning on using your Power Vision I recommend you check out Fuel Moto's website. Jamie has several dyno graphs with various configuration (cams, intake, exhaust) posted on his site, he buys a new bike every year just for this purpose. He also has headers for 17/18 bikes and a nice selection of mufflers.
Old Oct 8, 2017 | 10:18 PM
Doshounds's Avatar
Doshounds
If you are going for performance. D&D will get you there. There are few if any exhaust systems that will flow enough to handle the M8 with increased cubes, high compression, high lift cam, and CNC ported heads. The D&D M8 system is barely enough to handle the M8 in a high performance application, however, it is one of the better options out there at the moment.
Old Oct 9, 2017 | 10:17 AM
hellbilly78's Avatar
hellbilly78
Im doin my performance research as well incase my bike is totaled and the cyclerama 460 cam looks awesome. My twin cam had a fuel moto 107 on it with head work makin 113ho 130tq. A m8 with exhaust air cleaner tuner and that cam is makin close to those numbers. If i recall the numbers i seen were 107hp and 118tq. But the tq curve looks awesome from the bottom pretty much all the way up. Mine didnt hit strong until 3-3200rpm. Hope this has helped
Old Oct 9, 2017 | 12:36 PM
goblue90's Avatar
goblue90
I ordered the CR460 cam this morning. It came down to either the TTS100 or the CR460 and I decided on the latter. Anybody know of a good ship in the Philly area? I'm avoiding area dealerships as they've all quoted me 8 - 9 hours for cam installation.
Old Oct 9, 2017 | 03:06 PM
Bannana Boat's Avatar
Bannana Boat
Haven't tried the Cycle rama's but the dyno sheets Sheffer HD (on their fb page) has on them show nice gains. The TTS-100 is a great cam as well. I have the TTS-200 and luv it. Super smooth and powerful. If you are concerned about having it be as loud as a twin cam, dump the stock header. I have the Fullsac Mx head pipe and it sounds waaaay better, is louder and performs better. Also, if your going SE on the breather, the heavy breather puts up the best numbers and looks great on the RG.
