2017 ultra limited m8 oil light
Old Nov 13, 2017 | 01:29 PM
GZRGLYD's Avatar
GZRGLYD
Stage II
Default 2017 ultra limited m8 oil light
I have a 2017 Ultra Limited with the M8 and the oil light keeps coming on. The first time I took it to the shop they told me it was the ECU and they had to special order they parts. they said it was okay to ride until the parts arrived. 2 weeks later i'm stuck on the side of the freeway for 2 hours waiting for a tow truck with a huge puddle of oil under my bike. They replace the ECU and the oil pressure switch. A couple of weeks go by and the oil light comes back on, I take it back to the dealer and after several days they inform me that its a low voltage problem. This time they replace the stator. A couple weeks go by and my bike is now back at the dealership with the oil light on. Any ideas?
Old Nov 13, 2017 | 01:33 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
It's the oil pump and by the time your dealer gets the word, you are going to need an engine.
Old Nov 13, 2017 | 02:23 PM
ntg433's Avatar
ntg433
To what do you attribute the oil puddle? Did they not properly replace the sensor when they checked the oil pressure? When I had problems with the oil light and low voltage they tested three things: oil pressure switch resistance, proper grounding and the ECU. Everything tested ok.
They also cleared out all codes and sent me on my way. It's been about 1K since then and none of the oil codes have returned. I'm keeping a wary eye on it just the same. My confidence in what the dealer tells me is "buyer beware."
Old Nov 14, 2017 | 08:10 AM
riknbeth's Avatar
riknbeth
Same bike... Oil light has come on twice after startup (does not go off). Shutoff bike and re-started oil light off and no issues. Dealer checked it out with no issues. Tech said it was fine and the sensor does not reset sometimes, he has seen this before. Keeping a close eye on it. 12K miles has happened twice thus far.
Old Nov 14, 2017 | 09:13 AM
jpooch00's Avatar
jpooch00
Default Typical "tech" BS.
Anybody who tells you that it's OK to run ANY engine with an indication of excessively low, or no, oil pressure without physically checking to see what the pressure actually is is an idiot. Pretty much sums up the intelligence of most H-D "techs" for sure.
What does the owner's manual have to say on the subject? Probably just the opposite, I'd think.
Hopefully, when they install a new engine (if they do), they'll also find, and maybe even fix, the problem.
The truly realistic approach would be for the MoCo to just ship an extra replacement engine (with matching numbers, natch'), right in the shipping crate with every bike they build and shove out the door.
Yeah, that's the ticket!
Old Nov 14, 2017 | 11:46 AM
GZRGLYD's Avatar
GZRGLYD
Stage II
the puddle was from the oil pressure switch, each time they have "fixed the bike" its been good for about 1500 miles. I'm at 17000 miles now and the bike has been in the shop 4 times for the same thing and H-D doesn't give a ****. I've been loyal to H-D for almost 30 years this is my 4th Ultra since 2008 and I ride almost 30000 miles a year. Sad to say but I have scheduled a test ride at the local Indian dealer.
Old Nov 15, 2017 | 06:47 AM
jpooch00's Avatar
jpooch00
Hey, quit yer bitchin'. There's one guy posting on the forum that doesn't get that many miles out of each replacement engine they give him.
It's all relative. 1500 miles between "fixes" doesn't sound that bad, comparatively.
Old Nov 15, 2017 | 08:35 PM
Timberwolf2017's Avatar
Timberwolf2017
"Hopefully, when they install a new engine (if they do), they'll also find, and maybe even fix, the problem."
HD does not even know what the issue is, much less how to fix it. First it was metal shavings, then sensor, then wiring, then infotainment that reads sensor, then oil pump, then trans oil migration, sumping, then
How many of the early production bikes will have issues down the road? or engines that will grenade because of oil issues? Honestly, if it were not for the lifestyle and the image that surrounds HD, they would have went out of business long ago.
Old Nov 16, 2017 | 06:52 PM
psyshack's Avatar
psyshack
It's a extremely cheap switch. And should not be trusted.
Old Nov 16, 2017 | 06:59 PM
mjwebb's Avatar
mjwebb
yeah but his wasn't the oil light it was the 'Replace Engine Soon' indicator lamp..JK..these are absolute horror stories for loyal customers
