Sumping is where residual oil in the case is overwhelming the sump/scavenger/pump system and filling the crankcase thereby interacting with the crank/flywheel/counterbalancer causing heat, foaming, and eventual catastrophic failure.
I just pulled 16oz out of my primary and I am pretty sure it did NOT come from the transmission. I have been keeping tabs on the transmission level, I did add about 3 oz over 4k miles.
Trying to figure out how an extra 16oz made it into the Primary. Would that be the oil pump issue then?
No, it is not the sumping issue or oil pump. there have been reports of the crank seal allowing eng oil into the primary, sounds like what you have going on. do you do your services? You have to rule out that it was not overfilled at last service.
Do you know for sure it wasn't overfilled in the first place? 16 oz over is a lot. I don't think the sumping has anything to do with the transfer problem.
1k service done at dealer and I was about to do the 5k. Stopped when the primary turned into a waterfall.
So crank seal is the possible culprit? According to a TSB I had read, it cited oil pump.
Yes, if eng oil is in the primary, the crank seal is most likely the cause. Some have been found to be torn during installation at the factory.
Bike is at the Dealer.
Per their conversation with HD corp, they had originally thought there was a crank seal issue but they said that had fixed absolutely nothing and have since stopped that recommendation. Now researching other possible causes.
