Quick Sumping/Migration question
Old Dec 7, 2017 | 08:34 AM
Beerbar's Avatar
Beerbar
Originally Posted by 2013superglideseattle
If you think the extra oil you found in the primary came from your engine oil, your eng oil light should have illuminated for a low oil level.
This happened on my 2017 rgs all stock. Eng low oil light illuminated at about 9k miles. Service dept. found a bad seal between engine oil chamber and primary chain case. Eng oil migration into primary is no longer happening after this repair.
Did not happen in my case. The only indication was low oil on the stick.
Old Dec 7, 2017 | 10:07 AM
2013superglideseattle's Avatar
you should have your oil sensor check. It seems it failed what is supposed to do. Detects eng oil abnormalities.
Old Dec 7, 2017 | 11:13 PM
SoCalHDMC's Avatar
SoCalHDMC
Huh??
Old Sep 4, 2019 | 10:42 AM
TriGeezer's Avatar
TriGeezer
The primary is a separate chamber from the engine oil, and is not affected by the oil pump. So, no...migration in the primary is not affected by and improved oil pump...
Old Oct 1, 2019 | 12:43 PM
piper59's Avatar
piper59
Well I hope they've got all that crap figured out.My 2016 SGS just flooded in TS Imelda so it looks like I'll be getting a new M8.If I do buy new it will be a 2020.The new SGS's are too damn expensive especially with all that black crap on em.( no offense to all you black crap lovers).So I suppose I'll be getting a 107 and more than a little freaked out about all the sh*t I've heard on the M8's.I've also heard about most that have no problems whatsoever but my luck here lately has been heavy on the bad side.
Max Lam
Ironhead
28
Sep 21, 2025 08:24 AM
bennenrkc
Ironhead
Jun 18, 2014 10:32 AM
73 shov
May 5, 2012 08:46 AM
turbo54
Oct 19, 2008 06:23 AM
pitbull1
Ironhead
Oct 17, 2008 08:48 AM
