Thanks again Stone Cold
Old Sep 25, 2019 | 10:40 AM
Bumpandrun's Avatar
Bumpandrun
Default Thanks again Stone Cold
With all the negative and whiner posts just wanted to thank you Stone Cold for taking the time on the "FIX" series. Now servicing 5 of these m8s and my personal. Mine never really tranfered all that much and to be honest i dont check oils much. But we had one that was doing a lot more than others. Now all 6 i have milled the covers. None have had anything else other than the AIM Clutch release piston done. 6 bikes with 22k 34k 36k 76k 78k 90k none have ever tranfered again. So again thank you for doing the work. 2 of these bikes even had a fat rod i guess they call it and still transfered... these guys wont go too dealers so non have vented primarys other than my halfazzed test with starter bolt thats now removed.
thank you again.... and this is not a debate.....just a thank you. Cam series also helped a bunch
Old Sep 25, 2019 | 10:50 AM
RinTin's Avatar
RinTin
You have 3 M8's with 76k 78k 90k miles on them? What work have they need? All stock engines?
Old Sep 25, 2019 | 09:05 PM
not a sock's Avatar
not a sock
I had $tone's fix in my '18 Ultra and it fixed it from transferring as well.
I was (slowly) putting my '18 back to stock (removing $tone's kit) for
trading when I thought I'd try an AIM slave cylinder to see how easy it
was on my broken hand.
Not only was the clutch EXTREMELY light;
it also cured the Trans oil transfer. (I assumed it would start again without $tone's
Trans Oil Transfer fix)
I have ridden the bike 1500 miles on the AIM cylinder and the Trans oil level
is right where it should be (where I set it; HD of Asheville))
Old Sep 25, 2019 | 09:25 PM
jlombard's Avatar
jlombard
The Harley vent is all you need to fix the transfer.
Old Sep 26, 2019 | 11:50 AM
bigcraig's Avatar
bigcraig
That has been proven not to be a 100% fix. (Based on threads in this very forum and I have personally seen a bike that it did not completely solve the issue.)
Old Sep 26, 2019 | 02:55 PM
Bumpandrun's Avatar
Bumpandrun
Pretty sure you got lucky....i had the AIM cyl in mine it didnt change the little bit i had tranfering .....but had the AIM go bad and while i was changing it i did cut my cover....went to no transfer what so ever. ( AIM By the way was great to deal with) Its been 12 k and i havent changed trans fluid on purpose to see if it ever did. The funny thing is my twink transfered more than my m8. But never cared as i mostly changed all 3 holes ever4-5 months or 7500-8000.
but thats my last word as i dont want too get the warranty crowd hog groups panties in a wad..... thank you again for the RD Stone Cold
Old Sep 26, 2019 | 06:35 PM
$tonecold's Avatar
$tonecold
You're welcome! I'm glad to see that relieving the side cover worked so well for you and your friends. I believe a relieved side cover with the vent would be an absolute fix, as good as "The Fix", and it's hard to beat a seal when it comes to controlling oil.
Old Sep 26, 2019 | 07:22 PM
bigcraig's Avatar
bigcraig
Stonecold, I can tell you this.
I have done at least 6 trans cover jobs for friends, all have stopped transfer. (No fat rod, no vent but 3 of the 6 also got AIM slave cylinders.)
But again, all stopped transfer.
Old Sep 27, 2019 | 04:58 AM
Steel Wheels's Avatar
Steel Wheels
Another here who’s benefited from Stones research. 7K since the cover mod, and still no transfer. No need to put a hole in the primary.
Old Oct 1, 2019 | 02:33 PM
South107's Avatar
South107
I just had the vent installed and still transfer 3oz in 1000k.
bummer!
Dazzauk
Mar 24, 2016 02:41 PM
Ruggs59
EVO
20
Oct 22, 2015 09:16 AM
93FXRP
EVO
Apr 27, 2014 01:29 PM
bigfish_Oh
Nov 16, 2011 01:48 PM
Rockrspud
Jun 17, 2010 09:13 PM
