Maybe Its Aliens
Old Dec 8, 2017 | 03:05 PM
lp's Avatar
lp
The air blast is normal. It's what happens when the pistons come down.
Old Dec 8, 2017 | 03:12 PM
Mattbastard's Avatar
Mattbastard
Doing this helps get what, that last 0.5% of the dirty oil out of the passages and replaces them with air? Now your pump has to move air (which it's not designed to do) until it can suck up enough new oil to begin the delivery of new oil.
SMRT...
Old Dec 8, 2017 | 03:19 PM
Thingfish's Avatar
Thingfish
Guess I've never noticed it before. Maybe it's less obvious when opening the fill spout first.
Old Dec 8, 2017 | 04:34 PM
judgedelta's Avatar
judgedelta
I experienced a blast of air like that one morning after having the super Mexican fiesta combo-plate the evening prior. Blew my socks down around my ankles.
Old Dec 8, 2017 | 04:51 PM
DaddyKnuck's Avatar
DaddyKnuck
If the engine is pumping enough air to pressurize the oil tank (pan) you'd feel it when you pull the dip stick as well.
I think this guy is opening the crankcase to drain the last little bit.
Old Dec 8, 2017 | 05:05 PM
Thingfish's Avatar
Thingfish
Makes sense. Just sounded more violent the way he described it.
Old Dec 8, 2017 | 05:13 PM
Cbyway's Avatar
Cbyway
There are things in this world some tend to take a little too serious. Draining the oil for an hour, then starting the engine with no oil to get that last little purge is one of them.
To me this is as extreme as taking advantage of the $20 nitrogen tire service the dealers run and making sure they run a vacuum on the tire before the nitrogen is pumped in the tire.
Comon Man.
Old Dec 8, 2017 | 05:38 PM
DaddyKnuck's Avatar
DaddyKnuck
Comon Man.
In the Shovelhead days, when oil filters were a little bigger than a roll of quarters, we used to pull the return line, after refilling the tank,
and let it run until clean oil came out.
There never was much dirty oil, and it was a great way to get oil all over the place. I don't think I'd ever drain the oil, and then let it run dry for even a few seconds. But, that's just me.
Old Dec 8, 2017 | 05:55 PM
Redrodyankneck's Avatar
Redrodyankneck
Originally Posted by jpooch00
So, I assume that the air-blast came just as the last of the oil was draining?
Somethin's definitely screwy there! The MoCo's only had, what, 115 years to figure out how to vent a crankcase? Maybe another century or so will give 'em time enough to muddle through a fix! Too bad Henry Ford's not still around, since the Model A's & T's didn't have this problem. He could give 'em a hand.
Give it up man! Tired of the same old dribble, no I will not put you on the ignore list. We get it, you hate Harley and they can't find their a** with both hands according to you......over and over and over again. No matter what the subject is you repeat how incompetent Harley is. Sell your outdated 2015 Twinkie and buy a BMW like all your buddies in the peoples republic of Colorado. You have outgrown your Harley roots.
Good thing I'm in a good mood.
Old Dec 8, 2017 | 10:11 PM
SoCalHDMC's Avatar
SoCalHDMC
Originally Posted by lyork
Agreed!!
Make that another one. I too cringe waiting for the valvetrain of any four stroke engine to quiet down as it builds oil pressure after an oil change. But to purposely allow an engine to run with ZERO oil pressure for A MINUTE???
That is like the proverbial nails on the chalkboard to me. I would have nightmares about bearing material disentgrating and kicking a rod out of the case. Just sayin'...
