Oil quantity
Old Dec 10, 2017 | 06:40 AM
Peter Quinn's Avatar
Peter Quinn
I actually buy and fill 4.5 lt which is 4.8 pts. Figure if you have the oil cooler & plumbing must suck up .3 when it is running anyway?
Old Dec 10, 2017 | 07:41 AM
PDB17UltraRG's Avatar
PDB17UltraRG
The manual said 4.5 but 5.2 works great for me right level is right were i want it.
Old Dec 10, 2017 | 02:20 PM
EdsRoadGlide2017's Avatar
EdsRoadGlide2017
Thank you for the replies everyone. l. My owners manual that came with the bike says start with 4.0qts. The 2017 owners service manual that I just got says 4qts also. My last bike a 2010 SG said 4qts and went right to the mark with 4qts. I only check my oil hot and have done 500 miles since adding the 0.5qt. No overflow or excess fluid anywhere. I just wanted to see what you all have experienced since I know that each engine can have its own personality. Thank you again for the wealth of knowledge.
Old Dec 10, 2017 | 02:22 PM
EdsRoadGlide2017
Originally Posted by 2black1s
I've only done one oil change on my Limited so far, with the next one coming next week. At the initial change it took 4 3/4 qts. to bring the level to 2-3 dots down from full, which is where I set it cold. When it gets hot it is right at the full mark.
The 2-3 dot difference between hot and cold is from my experience with my previous bike and this one seems the same.
this is the first oil change I’ve done myself also. I had the dealer do 1K and 5K service. I want to do 3K fluid changes so I did this one myself.
Old Dec 10, 2017 | 02:38 PM
Peter Quinn
Don't sweat it,you opened an informative discussion and we all learnt something from each other,which should be the prime motivation for these forums!
Old Dec 10, 2017 | 03:41 PM
EdsRoadGlide2017
im good man. Thank you!!
Old Dec 10, 2017 | 04:40 PM
Quik's Avatar
Quik
Glad to hear everything is staying in and yes you are correct, these motors seem to have all kind of different personalities. I know anything much over 4 qts in mine and it will frost my rear pipe and right saddlebag like a cupcake, drives me nuts but I roll with it. Ride safe!
Joe from So Cal
Jul 5, 2021 08:43 AM
rysonn
Oct 2, 2016 06:00 AM
4 inch pistons
May 9, 2012 04:28 PM
OneBlackFly
Oil Archive (no new posts)
Aug 30, 2006 11:21 PM
Jezcruzen
Aug 8, 2005 12:33 PM
