Kuryakan extended brake pedal awesome
Old Jan 9, 2018 | 07:06 PM
bikermikee's Avatar
bikermikee
Default Kuryakan extended brake pedal awesome
Just put this extended brake pedal on my 2017 road glide ultra. Best comfort upgrade I've done. No more lifting my foot off the floor board to apply the brake. And no more front braking in corners. This moves the pedal a bit forward and down closer to the floor board. So much easier to access. Not sure why this isn't the stock location. Highly recommend this for any touring bike or trike. Longer version available for bikes without lowers.
Old Jan 9, 2018 | 10:40 PM
Fullbore55's Avatar
Fullbore55
Today I installed the Kuryakyn one that is for bikes without lowers. Removing the cotter pin on stock lever was a pain. I had to loosen and move engine guard out of the way to get extended lever in place. Then getting the main pin thru extended lever and rear cylinder connection was bigger pain.
But nice now it’s done!
Old Jan 9, 2018 | 11:15 PM
SWMB's Avatar
SWMB
Totally agree
Old Jan 10, 2018 | 11:25 AM
dan_tominovich's Avatar
dan_tominovich
Do you have to use floor board spacers? I know you do on some of the other brands. I would like this upgrade too. My foot dosen't bend as much as it used to.
Old Jan 10, 2018 | 11:32 AM
smitty901's Avatar
smitty901
I have the same one in Black on my 2017 RGU . It was not hard to install. Required nothing special to install it.
Old Jan 10, 2018 | 11:47 AM
dwagar's Avatar
dwagar
I put both the brake and toe shift levers on mine. What a great upgrade.
As said above, that cotter pin is a bitch, especially with 65 year old eyes.
Old Jan 10, 2018 | 11:48 AM
beasleyiv's Avatar
beasleyiv
Is that the 9672 pedal? If not, which part is it?
Old Jan 10, 2018 | 12:21 PM
bikermikee's Avatar
bikermikee
Yes its the 9672
bikermikee's Avatar
bikermikee
Yes, I have the kuryakan floor board spacers installed as well but no it's not required
Old Jan 10, 2018 | 01:16 PM
Clutched's Avatar
Clutched
Just got a 18 RGS this fall only got 850 miles before the Snow,But I was cramped Compared to my Street Glide,Changed HandleBars Big Improvement,Got rid of the heel shifter an put spacer on an moved foot shifter to the outside much better an put floor board spacers on much better but that brake pedal has to go will be getting one of those brake pedals before spring,Sick of lifting my foot up,Do they Come in Black?Got to get a reduced Clutch lever also an will be set.
