Engine Error codes
Old Feb 9, 2018 | 11:41 AM
micmoren's Avatar
micmoren
Default Engine Error codes
We replaced the fuel rail yesterday on a friend's 2017 Ultra Limited after he broke it by trying to remove the tank w/o disconnecting the fuel line. We swapped the injectors to the new rail, buttoned everything up. Started up fine. Today, he is getting these codes:
P264 - rear injector high pressure
P261 - front injector low pressure
What could be throwing these codes? We connected up the connectors to the injectors correctly. We didn't note which injector was on which side, not thinking they were front or rear specific. Are they?
Thanks in advance for the help.
Michael
Old Feb 9, 2018 | 12:17 PM
2black1s's Avatar
2black1s
Low and High referenced in the codes are not pressure, they are rather electrical references, i.e., resistance, voltage, amps, etc.
I'd start by disconnecting the connectors, check for contamination, check the barrels and pins for distortion, shoot them with a little WD-40 and cycle the connectors (connect/disconnect) a few times and then see if the codes re-appear (after clearing them first of course).
Old Feb 10, 2018 | 08:09 AM
wadejesu's Avatar
wadejesu
Default Codes
Try clearing codes with diagnostics mode, Injectors are Front rear specific, Rear cylinder shuts down at idle when hot to reduce engine temp.
micmoren
Milwaukee Eight (M8)
Feb 9, 2018 07:26 PM
Dented
Apr 8, 2017 12:23 AM
jfsanchez79
Engine Mechanical Topics
Feb 1, 2017 05:51 PM
Antonio Balls
Jun 13, 2014 07:29 AM
captharley
Apr 5, 2008 10:17 AM
