My bet is the slip ons the M8 especially in stock or stage 2 is effected a lot by exhaust. Keep the baffle size at most 1.75 and you'll pick up the low end tq you're looking for. Bigger baffle may sound better and make you think you're going faster but 9x's out of 10 the opposite is true.The street cannons are the max baffle size you should have and I think for a basic stage 2 they are slightly to free flowing but better than many with 2" baffles.
Bigger = sound little better higher hp number by a couple lower tq.
Put your old slip ons back on bet you'll feel it respond better,granted top end hp will suffer.
OP - What you have is an anemic cam. I made the same mistake thinking I would be impressed with the newfound down low torque. A bit more torque up higher and a bit less down low...where I wanted more.
Just pick one of the cams tested by TTS and Feul Moto. They all kick the 447s ****.
As soon as I get time to swap to another, much better cam, I will.
Bob
Free dynos must be great money maker for the dealer, surprised theyre not common practice.
(Getting advice on a forum is like getting a sip of water from a fire hydrant)
I think it's one of the smartest ideas they ever came up with. They also include free pick up and return of your bike, at least in the winter months.
But, the day I was there, there were only 3 bikes to go on the dyno. I'm shocked more people aren't taking advantage of it. Possibly, the average buyer just doesn't care.
Bob
If I was out of warranty, I'd have the TTS100, TTS tuner, and Fullsac pipe on there. But I'm not.
So I'm looking for a one year solution.
Why not try the Thunder Torque Inserts, have your dealer give you another spin on the dyno to see if it alleviates your problem and moves your torque to the left. If it does and you're OK with the sound, run them for a year until you can do as you wish. If it does and you don't like the sound you can try different mufflers.
If you looked at Steve Cole and my cam testing you will see that it was done with the sparsest of equipment: Hi-flow air cleaner, recored stock mufflers, decatted header. We got as good or better numbers out of most of the cams as what other testers have gotten.
Thanks, yes it was your test and other tests that Steve Cole has done that made me think of the slip ons. I think you were using 2" baffles? And I'm sure I've seen other tests he has done where he's recommended 1 3/4 or 2".
I'm just wondering if anyone has seen a chart crater on the left like this with 2 1/2" baffles. If it's actually a Street Tuner issue, there's little I can do about it.
I will test it with the inserts, if Spring ever comes. An inexpensive way to check it.
An even less expensive & way easier way to see if it's the mufflers is to put your stock mufflers back on. There's a couple of people here running the TQ cam & street tuner with stock mufflers & they say the performance is good. You can change mufflers in about 15 minutes, to try the TQ cones you have to remove the headpipe, more like an hour or two. The SCs might perform a little better & sound quite a bit better, but the stock mufflers should show you if it's the mufflers that's holding the TQ back.
OP, I don't know what to tell you, but -- that chart looks awful. I just looked in the big book and, according to Harley's charts, the 447 in a touring bike should be delivering 100+ ft/lbs at 2500, 106+ at 3000 and 108 at 3500.
You should be showing 95 hp at 5500 RPM.
Everything on your chart is low, but the low-end torque looks just wrong. I don't know if it's the slip-ons or the old winter gas or what, but that ain't what a 447 Stage II bike should look like.
That’s a great idea.
The Torque Cones mount where the baffle mounts, you don’t have to remove the header. But I checked my V&H slip ons, the bolt hole does not go through, so mounting them would require I drill them out. I’d rather not do that.
